Westinghouse 19" lcd
  • bigedinphoenix
    • Mar 2009
    First of all I want to thank you all for having this site ...it has helped me with these westinghouse monitors. I purchased 7 used units all of which were not working and all h;ave the same symtom. In your archive you recommended change out of all caps which I have already done. I did find the small fuse with an open and have bridged it with solder and now have the reading value of 14.89 volts dc at jumper 204, this worked with one unit. but the others have still got a way to go I get good votage comming out of one mosfet but the othe only has voltage in the center pin. Now the symtom has changed to green led blinking and backlight fickering but not remaining on. Should I change out the mosfets and can you please advise me on how to know if I am shorted out somewhere.
    Thank you Very,
    ED
    Bigedinphoenix@yahoo.com
  • PlainBill
    • Feb 2009
    • 7034
    Re: Westinghouse 19" lcd
    Thank you Very,
    ED
    Ed,
    I'd suggest taking this thread to the 'Troubleshooting Compute Displays' subforum on this site. They already have a thread on Westinghouse LCD displays.
    PlainBill (also in Phoenix)
    • bigedinphoenix
      • Mar 2009
      Thank you for the suggestion...
      Ed
      • alro7779
        Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
        by alro7779
        Hello, guys!
        I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
        Alex....
        10-03-2025, 05:49 PM
      • Nicktronic
        Westinghouse W55UW4620 No Video
        by Nicktronic
        Ok, so I know I know, it's a Westinghouse....lol It's got the backlights but no video. Likely the panel, but I'd like to take some measurements on the buffer board with help from you experts to confirm. See the attached pictures. In pic #1, there's a nice pin reference to use to take some measurements. The large IC in pic #7 gets up to 60degC when the TV is on.
        So, backlights, no video, go! 🙂...
        06-03-2024, 03:21 PM
      • EBW
        Help Request - Westinghouse 32" Smart TV (Model: WD32HBR105)
        by EBW
        Westinghouse 32" Smart TV (Model: WD32HBR105) . Originally stuck on logo with no response from remote and no firmware file available to flash via USB. Westinghouse Support stated it would require service but that wasn't a cost effective option. I used dental floss to remove the motherboard processor heatsink to identify what make it was (Mstar). Unfortunately that knowledge didn't help with a solution. After the heatsink removal it only displayed a completely white screen. I then decided to replace the motherboard with a universal 3-in-1 board but the white screen problem continued. This...
        10-27-2022, 06:32 PM
      • Seville
        Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply
        by Seville
        Hello all!
        Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply .
        I have a Westinghouse LED TV, model WD48FAB100 that is not powering on. Upon removing the back cover, I noticed a burn mark where the AC cord connects to the power supply/main board. In this model, there is only one board combining the two functions. Previous owner said the TV experienced a lightening strike, but who knows. I checked the main fuse, tested OK. Here are a collection of readings from the power supply ports. Looking for some guidance on what to test/check next....
        10-10-2022, 07:31 AM
      • JayPoorJay
        Westinghouse Roku WR58UX4019.To be or not TV,,, That is the Question
        by JayPoorJay
        Hi All... Me again. Begging for help. The guy who now believes it's possible to fix a TV (one of the millions) one can find on the streets of NYC. I hate hate hate waste...
        Thanks to y'all's help I fixed and am happily watching a 70inch Sharp Aquos. Perfect. Learned a lot, replaced LEDs. Pulled screen/panel. Proud.
        This is a newer set. It's a Westinghouse Roku WR58UX4019. It was RIGHT outside my place literally, and I couldn't resist. 58in. 500$ new, but I'm not a rich man. So, I want to try.
        There is sound. It turns off and on. Screen is black. I can...
        03-17-2022, 05:27 PM
