See this :
https://www.badcaps.net/forum/showpo...39&postcount=9
I replaced the sockets with the connector/cables from a dead Proview 700P that was thrashed after a recap failure (board was melted, and I removed any component I saw that wasn't damaged, and the connectors too...).
I use it to test the lamps. It can not tell you if they draw much current, but can tell you if they lit or not. I power it using a modified ATX PSU for that purpouse, but if you get your hands on an old AT PSU (those with the switch), you can use it too, or even get the power from your computer's PSU. I made another one for a friend (the Tester) and he powers it up with an external Power brick used in those USB to IDE/SATA kits (he's limited to two amps and some really long lamps, like some 19" and 20" & up) don't lit, but then he takes them to my place for testing.
Well, you get the idea. It can be done, it is cheap (way less than 69 pounds), and it can save you some troubles ....
