Benq G2255 doesn't power on - amber power light when plugged in - part 2
+ More Options
Posts
  • will62
    • Dec 2016
    • 229
    • usa
    #161
    Re: Benq G2255 doesn't power on - amber power light when plugged in - part 2
    You could go up to 1.5A on the regulator. If the esr on the capacitor is good, I wouldn't bother with changing it. If any doubts, remove it from circuit.
    At this point, you might consider temporarily cutting the 3.3V line and connecting a 1A fuse and a meter to monitor current draw as you go through the stepped connection process.
    • rddube
      Aspiring Expert
      • Jun 2013
      • 949
      Ok Will, I think that is an excellent idea. Could you just explain how I would hook up the meter? Between the fuse and line?
      Also, I will certainly monitor the temperature on that mosfet as I test it next time. I read that the more current, the more they heat up. I think I am going to get some TO-220 regulators and maybe put a heatsink on it with a small fan in the monitor. Anyhow, I'll test different things.
      Thanks for hanging on in there with me Will, I feel so confident with you in the driver's seat!
      Ordered all the parts and have to wait a few weeks before coming back on. I'll keep you posted as they come in.
      • will62
        • Dec 2016
        • 229
        • usa
        #163
        OK. Cut 3.3V line from PS. Move red meter probe to 10A socket. Set meter to DC amps.
        PS 3.3V line to fuse to red probe. Black probe to line going to main. If you don't have any extra meters, you may want to pick a cheap one so that you can monitor at least one of the voltages as well.
        • rddube
          Aspiring Expert
          • Jun 2013
          • 949
          Ok, Will if I understand this well, the the meter is in circuit i.e. the 3.3v goes through it to make the measurement?
          Also, I do have 2 extra meters, so I'll be monitoring voltages as we go along. That little oscilloscope that I bought has a meter function as well...pretty accurate too.
          • will62
            • Dec 2016
            • 229
            • usa
            #165
            Yes, current is measured with meter in series. You might also get a few 700-800mA fuses. If a 1A regulator is on the PS, then the main is probably spec'd to draw a few hundred mA's below that. It would be nice to have the fuse blow before the TSUM gets fried.
            • rddube
              Aspiring Expert
              • Jun 2013
              • 949
              Hi Will,
              Just to keep you posted. I got the parts to repair the power supply. Have changed the regulator and am ready to test. Should I test it under load, say 10W 10 ohms resistor that I have?
              Still waiting for the TSUM ..........got the fuses 800ma..so in check!
              • will62
                • Dec 2016
                • 229
                • usa
                #167
                That resistor will load about 330mA. You could try it, but that's probably less than half of what the main will draw, so it won't tell you much. You could just wait until the TSUM arrives.
                • rddube
                  Aspiring Expert
                  • Jun 2013
                  • 949
                  Ok Will, the TSUM came in yesterday and I have started to solder it. Unfortunately, some of the pads are starting to lift from the board, but I think I didn't break any of them, except for one that i had to solder over the pin!?!
                  Still checking it out and doing some final touches before I call it a go for testing. BTW, I should mention that when I ordered the TSUM's the store that had them on AliExpress also had the other board that looks exactly like mine but not the same model. I ordered it at the same time (thinking that if my board goes bad, I'll have a backup just switching the flash and eeproms. It hasn't arrived yet, it was not with the TSUM's so we'll see.
                  I'll try and get this board working with the 800ma fuses and checking amps like you suggested within the next few days. I presume the fuses is on the 3.3v line or is it on both the 3.3v and 5V? I'll keep you posted. Tks.
                  • rddube
                    Aspiring Expert
                    • Jun 2013
                    • 949
                    I'll start by checking my voltages on the power supply and go from there.
                    • rddube
                      Aspiring Expert
                      • Jun 2013
                      • 949
                      Ok, so checked my voltages on the power supply, at first I had a nice 5.02V on the 5V line and 2.87V, moving to 3.22V and after about 5 -6 seconds it jumped to 4.9V on the 3.3V line!!
                      Checked again, 4.9V on the 3.3V line, so I disconnected everything and checked the mosfet and guess what, it was showing .1 ohm between the 5V side to the 3.3V side. So the power supply is cooking that regulator. I still have 1, 1amp left and 2 1.5amps plus the other formats. But I won't budge until I hear from Will.
                      • rddube
                        Aspiring Expert
                        • Jun 2013
                        • 949
                        I am posting a photo of my board for easier reference, as part 1 of this thread has been a while! Please bear in mind that these are the original photos from the start, and that all caps including the big one were changed for either Nichicon or Rubycon caps, except the C703 (25V 220uf) which is a Panasonic.
                        I think we are back to the root cause for the 2 threads (part 1 and part 2) and that the 5V line seems to be causing something that fried the 6133 regulator to cook. Initially (at the beginning) the 3.3V line was fine but the TSUM on the main board had fried probably for the same reason?
                        Any thoughts anyone?
                        • rddube
                          Aspiring Expert
                          • Jun 2013
                          • 949
                          Just finished checking the voltages on the power supply, and the 5V line looks very good, even under the oscilloscope. So I'm thinking, maybe it changes when there is a load, but yesterday when I was checking and it blew the 3.3v regulator, I had no load??
                          I'm thinking of connecting a 10W 10ohm resistor on the the 5v line, which I think would draw 2 amps, and then check how it behaves? Is this a good idea or will I fry something else? Tks.
                          • rddube
                            Aspiring Expert
                            • Jun 2013
                            • 949
                            So I ended up checking everything (or almost) on the power supply board and nothing looks bad, so I thought maybe when I soldered the 61-33 regulator, I might have put too much heat.
                            So I installed a 1.5a regulator and tested the power supply board with only the cfl's connected. Nice clean 5V and 3.3V. So I'm off to test the power on sequence that Will62 wrote in a prior post. I'll be back for an update.......
                            • rddube
                              Aspiring Expert
                              • Jun 2013
                              • 949
                              OK, so did this:
                              1. Jump 3.3V and ground to the main.
                              2. Jump 5V
                              3. Connect keypad
                              If you get here w/o any problems, check what the led is doing at power up and if the main is putting out the ps_on and dimming signals.
                              4. Connect lvds cable
                              Before the last step, check the ps_on, dim, and pwr_saving pins on the power supply. Any unexpected voltages?
                              All voltages look fine, however the green light comes on on the keypad. The 3.3V line is pulling approx. 6.3 milliamps, the TSUM is not heating up, neither is the regulator, but the green light is on. I stopped there before connecting the power supply to the main board. I have the fuse (800ma) on the 3.3V line.
                              • rddube
                                Aspiring Expert
                                • Jun 2013
                                • 949
                                So I checked the TSUM soldering again and found 1 bridge which I removed. Now the green light does not come on, only when I press the power button. So I connected everything keeping a close eye on the TSUM and the voltage regulator (temperature)...everything seems to work perfect, except that now I get the 2 seconds to black symptom. Tried it a few times, maybe 5 and yes when I power on the green light comes on, the CFL'S light up but after about 2-3 seconds everything goes dark.
                                • rddube
                                  Aspiring Expert
                                  • Jun 2013
                                  • 949
                                  I believe I have found the power and inverter board schematics for my monitor, at least they look very close. Posting it here for reference.
                                  • rddube
                                    Aspiring Expert
                                    • Jun 2013
                                    • 949
                                    Ok, upon reading some of the other threads on 2 seconds to black, I saw one that suggested to resolder the transformer pins and the ccfl connectors (Will had mentionned that too).
                                    So I rechecked everything and redid all solder joints including the high voltage capacitors (even the Frankenstein one that Will showed me how to make) and retested again, and voilà, everything works!
                                    The screen comes on and stays on, and it's asking for an input. I left it on for approximately 10 minutes (as I was suspicious) checking the temperature of the TSUM and the 5V to 3.3V regulator, and all looks well.
                                    So I'm going to leave it to that and wait for Will62 to logon and see if he thinks I should do anything else before reassembling and testing.
                                    It's pretty amazing that it works, but I am somewhat suspicious because this is the 3rd TSUM it had fried the first two.
                                    • rddube
                                      Aspiring Expert
                                      • Jun 2013
                                      • 949
                                      Ok, it's been running fairly well and I have been monitoring the heat on the boards without the cover back on, and noticed that it seems to heat up to 28/29 C.
                                      So I installed a video card fan inside the assembly and now it's keeping it cool. I have fully assembled it now and have been testing it for over an hour and all is good.
                                      I'll leave it on for a while and see how things go, but I think this time it's good.
                                      Thank you to everyone and especially Will62 for helping me out in this great project!
                                      • PantherDave
                                        by PantherDave
                                        Hi all!
                                        05-29-2024, 02:01 PM
                                        by sam_sam_sam
                                        03-31-2024, 02:12 PM
                                      • Noodneek
                                        Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                                        by Noodneek
                                        My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                                        I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                                        08-30-2024, 12:52 PM
                                        09-06-2024, 05:59 AM
