Acer B326HUL power supply dead
  • fred41
    • Feb 2012
    • 9
    Re: Acer B326HUL power supply dead
    Hi, I finally gave up and payed a repairmen to repair it...
    • the.norbulus
      • Apr 2019
      • 12
      Thanks for the reply You're back up and running now which is the main thing. I hope it didn't cost you too much.
      • fjaffre
        • Nov 2020
        • France
        Originally posted by Behemot
        It's very difficult to read anything in here but it seems like the PFC/quasi-resonant flyback controller is NXP, possibly TEA1751T. According to the datasheet, the startup voltage is 21-23 V so when it's at 18-19.6 that's too low.
        The path goes from the auxiliary winding on primary side through inductor to an SMD diode, capacitor and than there is "K415 C200" TO-92 bipolar transistor. The 15V feed leads to its collector, the oscillating 18-19.6V output is on its emitter. Collector and base has 1002 SMD resistor in between and base is also connected through an SMD zener to return.
        So it seems like some amplifier with zener feedback? And this is to feed the Vcc of the controller.
        Bonjour à tous, je recherche de l'aide pour réparer mon écran ACER B326HUL. Le problème semble venir de l'alimentation, aucunes tensions en sortie.
        J'ai contrôlé les tensions sur le transistor K434 C200. Sur la base et le collecteur j'ai 11v et l'émetteur 17v. Vous dites que le circuit TEA1751T démarre à partir de 21-23v.
        Je ne parviens pas à comprendre d'où vient le 11 volt et donc de trouver pourquoi j'ai si peu. J'ai mis la photo sur casimage pour avoir une meilleur définition : https://nsm09.casimages.com/img/202...20717115189.jpg
        Si quelqu'un peut m'aider, je le remercie d'avance.
        Hello everyone, I am looking for help to repair my ACER B326HUL screen. The problem seems to come from the power supply, no output voltages.
        I checked the voltages on the K434 C200 transistor. On the base and the collector I have 11v and the transmitter 17v. You say the TEA1751T circuit starts from 21-23v.
        I cannot understand where the 11 volt comes from and therefore to find out why I have so little. I put the photo on casimage to have a better definition: https://nsm09.casimages.com/img/202...20717115189.jpg
        If anyone can help me, I thank them in advance.
        • fjaffre
          • Nov 2020
          • France
          • Andreas_de
            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
            by Andreas_de
            Hello!
            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
            04-12-2025, 10:38 AM
            by sam_sam_sam
            03-31-2024, 02:12 PM
          • bripoll
            Acer Veriton N4670GT Dead
            by bripoll
            Hello, I have an Acer veriton n4670GT that, due to a fall to the ground, only started if I did a BIOS reset.
            The power button ar ok, and when power off windows, then if press power button, this power on, but goes to boot loop, like press power button forever
            It crossed my mind to try a BIOS update and when I finished it turned off and no longer starts in any way.
            I have a flash programmer, but the file you download from the Acer website has a .CAP extension, it is not a .BIN
            I have programmed it, but it still won't start, it is dead
            Before programming...
            11-23-2023, 02:56 PM
            09-06-2024, 05:27 AM
