Re: Another HannsG HG281D
Thanks to all for the info on the Hanns power supply fix.
I just did the "three caps" fix. Changed C603, C606 and C707. The monitor came back to life beautifully. I have three Hanns 281's and three Viewsonic VX2835's. I had sent out two previous power supplies to be repaired, but then decided to attempt a repair this time.
I was looking at the power supply board with a magnifying glass, forgot it was still plugged in running in standby mode, and accidentally touched the metal frame of the magnifying glass across some pads or traces on the back of the board on the low frequency side.
I heard a bzzzzzzzzzzzzt, quickly moved the magnifier away, but it no longer kicks on.
I get the orange and blue LED power standby lights, but when it tries to turn on, I just hear a quick, faint ticking noise coming from the power supply.
I checked BUF07704 and got similar results to what rrflorida mentions.
U301 has INCOM of 0V, OUTCOM starts at 5V and climbs to 9.77V.
U300 has INCOM 5.47V, OUTCOM 5.55V steady which looks more normal.
Could I also have a failed BUF07704?
Though looking closely at the traces, it seems like INCOM and OUTCOM of U301 could be floating if that makes any sense.Last edited by Capt. Cap; 10-17-2018, 01:31 AM.Leave a comment:
Turns out it's not the ribbon cable
I got the idea to swap the two cables, and the right side of the display still works with the cable I thought might be bad, and the left side of the screen is still not displaying any picture with the known good cable.
I guess the tab bonding board is next to check?
Or could it still be a TCON issue?Leave a comment:
That's relieving to hear! Earlier today, I did Tom's T-CON board diagnosis spreadsheet mentioned here, and it had gotten me worried as it showed my VDDA as a Marginal/Fail, and "VCOM given to AVDD" (whatever that is) as an outright fail. But then again, it showed my VGL as failed also even though is was dead in the middle of the -5 to -15V range, so I guess should be taken with a grain of salt.
At this point, the issues does seem to have something to do with the ribbon cable or perhaps connector holding, since you said you could get an image if you hold it right. That rules out any dead IC on the T-con and TFT panel boards, I think.
I was also thinking it could be a tab binding board issue for the left side of the screen, so I tried checking the only test pads that I could access without figuring out how to remove the bezel.
VCOML_I, TPC2, and TPB2 were all 0V. An unpopulated solder pad was 770mV, so there is at least some power getting to the bonding board.
If you can find the cable (and maybe for a decent price too), it might be more worthwhile to just replace it than play around with measuring resistance/continuity from board to board.
I've got a new ribbon cable on the way, we'll see what happens when it's in place.
Ha, me too, budm. I think it was that other Samsung monitor thread we were replying to.
Sorry about the mixup, Capt. Cap.
Thanks so much momaka and budm for providing so much insight!Leave a comment:
I'm looking at replacing it, seems to be a 0.5mm pitch 80 pin FFP cable, but it has some lines missing from it.
I could sever the same wires with a razor blade, but would rather not risk screwing up the other lines on a new cable.
Do you guys think it would be fine to have continuity on the pins that have missing wires in this ribbon cable?
Yes, there's a chance the old cable may have failed where the 90 degree bends were. However, it could also be the connector not making good contact with the cable too. This, we won't know. But if you replace the cable and symptoms remain the same, then it's probably the connector itself.
Sorry about the mixup, Capt. Cap.Last edited by momaka; 10-15-2018, 07:43 PM.Leave a comment:
Regarding this ribbon cable on CN501, it is very finnicky - if I don't leave it with a little pressure holding it just right, the right side of the display goes from normal to faded and discolored.
What is weird is that this ribbon cable should be effecting the left side of the image displayed, since the cable is the one on the right side of the TCON when viewed from the back. Or am I completely off here?
I sometimes got lighter grey horizontal rectangles, about a half inch high and spanning the entire left side of the monitor when messing around with this cable (the right side image was ugly while doing this), but never anything else on the left side.
This particular ribbon cable was creased at a 90° angle coming out of the display's connector on its left side, and then creased further down on the right side. Also, the tape covering it was pressing it against the metal display backing, which seems to have heated it to the point where it made some discolored bubble patterns on the plastic. I've tried reseating the cable a few times and cleaning it with rubbing alcohol, but still no improvement on the left side of the display.
Also worth mentioning, I couldn't figure out how to get the ribbon cable released from the connector - a YouTube video I watched had the release bar flip up in the opposite direction from these ones, and I wrenched pretty hard on them before I figured out which way they flipped up. So I could have damaged the connectors, but I've looked pretty closely, and I don't see any broken connections with the TCON board.
I'm thinking (or hoping) that this ribbon cable was just barely hanging in there, and then jostling it around when removing the TCON finally did it in?
Is there a better way to test out a ribbon cable than checking the individual pin resistance across the cable and flexing it around? Sounds pretty tedious for 80 pins.
A pic of the current cable is attachedLast edited by Capt. Cap; 10-13-2018, 06:27 PM.Leave a comment:
Some more good news!
I removed FB14 and soldered in some copper wire across it, and got a consistent image on the right side of the display.
By gently pressing around on the ribbon cable at CN501 (right side of the TCON), I can nudge it into a position that yields a normal image on the right half of the display
I took readings from almost every test pad and some other places of interest on the TCON while the right side image was good, hopefully it can help determine if the TCON is OK and the problem lies downstream.
Scroll down in the box below to see all values
Code:VCC 3.31 VGL -10.14 VGH 23.3 VGH_M 19.99 VDDA 13.57 VDDR 3.30 VDD+18V 1.80 F400 4.87 L200 left side 5.40 (moving around) L200 right side 4.82 Gammas V1 13.25 V2 12.91 V3 10.68 V4 9.80 V5 9.27 V6 8.41 V7 7.35 V8 7.13 V9 5.57 V10 4.49 V11 3.92 V12 2.96 V13 0.66 V14 0.22 Other DEO 0 OE 0.61 SDA 3.30 SCL 3.30 TCONDRY 2.97 STV 0.01 CPV 1.07 MLG 1.84 VCOMs VCOML_A 5.53 VCOMR_I 5.47 VCOML_O 5.56 VCOMR_A 5.55 (some of the VCOMs are hidden behind a foam pad) U300 pin1 13.57 U301 pin1 13.57 STHF 0.01 FR0n 2.37 FR0p 0.13 FR1n 1.26 FR1p 1.24 FR2n 1.25 FR2p 1.31 FR3n 1.31 FR3p 1.18 FCLKn 1.25 FCLKp 1.25 FG0n 1.27 FG0p 0.13 FG1n 1.27 FG1p 1.24 FG2n 1.25 FG2p 1.24 FG3n 1.32 FG3p 1.18 FB0n 2.37 FB0p 0.12 FB1n 1.25 FB1p 1.24 FB2n 1.25 FB2p 1.24 FB3n 1.32 FB3p 1.18 STHB 0.01 LOAD 0.15 PCL 1.61 BR0n 2.36 BR0p 0.12 BR1n 1.26 BR1p 1.24 BR2n 1.26 BR2p 1.35 BR3n 1.30 BR3p 1.20 BCLkn 1.25 BCLKp 1.25 BG0n 2.37 BG0p 0.12 BG1n 1.26 BG1p 1.24 BG2n 1.25 BG2p 1.25 BG3n 1.30 BG3p 1.20 BB0n 2.40 BB0p 0.12 BB1n 1.26 BB1p 1.24 BB2n 1.26 BB2p 1.23 BB3n 1.30 BB3p 1.20
Momaka - resistances as follows were taken with board screwed into ground and ribbon cables in place, but disconnected from logic board (and power disconnected)
Code:VDDA 1.90kΩ VGL 141.8kΩ VGH 20.3kΩ VGH_M > 2MΩ
OK, sorry I got your thread mixed up with another thread about boards swapping.Leave a comment:
Some fine HannsSpree engineering for you thereLeave a comment:
One thing that is not really clear to me is that you said you use all the boards from working monitor to connect it to this LCD panel, does mean you also use the T-CON board from working monitor also?
I also see 4 IC's on the tab bonding boards also.Leave a comment:
VDDA should be at least 10V, and not uncommon to have it to 12-15V.
VGL should be negative and VGH at least 3-8V higher than VDDA.
So it looks like Q202 is indeed not getting switched and you are just getting a diode voltage drop from the input at F400 to VDDA (normal when nothing is happening).
With power turned OFF and the t-con disconnected, what resistance do you get to ground from test points VDDA, VGH, VGH_M, and VGL?
Voltage was sagging back to 2V at Q14 source, I started poking around on the 5V line, and noticed that the right hand side of the display flashed when I touched FB14. This time, there was a kinda stripey, greyed out image on the right quarter of the display.
Could this be a bad ferrite bead?
Any ideas what a suitable replacement would be?
How bad of an idea is it to just jumper over the thing?
What you never want to jumper across is any inductor (i.e. any "L"s). For example, the 6R8 inductor on the t-con board that is connected to MOSFET Q202 is an essential component in the generation of the VDDA, VGL, and VGH rails. So if you jumper across that one, you may blow Q202 and possibly other parts.
Ferrite beat FB14 on the other hand... no problems to jumper it.Last edited by momaka; 10-12-2018, 09:36 PM.Leave a comment:
For testing, you can bypass the Ferrite bead inductor and see what happen.Leave a comment:
I was poking around the circuit boards again today, and when I checked the front of the screen, on the right half of the display, a sort of faded, discolored image was showing!
I took all new TCON measurements (numbers look much better), had the computer go back to sleep while doing so, and when it kicked back on, the screen was all white again.
How bad of an idea is it to just jumper over the thing?Leave a comment:
TCON measurements follow
Code:VCC 3.32V VDDR 3.30 VDDA 4.59V VGL 0.46V VGH 0.59V VGH_M 0.18V F400 4.85V VDD+1.8V 1.80V TCONDRY 2.97 OE 0.61 DEO 0 SDA 3.3 SDL 3.3 V1 4.49 V2 4.37 V3 3.62 V4 3.33 V5 3.14 V6 2.85 V7 2.50 V8 2.41 V9 1.89 V10 1.52 V11 1.33 V12 1.00 V13 0.22 V14 0.07 4.83V on each side of L200
Also, I started checking out Q202 which is a 4468 30V N-channel MOSFET.
gate & source are all 0V, drain is 4.83V - seems like this should be getting switched on but it isn't?Leave a comment:
Bingo!
Well at least we know it's getting the right voltage input now.Leave a comment:
Never mind I just re-read your edited post #28, so now you do have 5V at the T-CON fuse then, correct?
What is the LCD panel model number? HSD280MUW1-A00 REV 0? If it is, then it runs on 5V instead of 12V that your main board version is designed for.
Yep, it's 1.5 Ohms and I just double checked all of the power pins, no continuity with anything else and Q14 source. BTW, this meter reads about 0.8V at continuity so 1.5 isn't that far off.Leave a comment:
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
by ant3202Hi Everyone
Lately I am experiencing the deja-vu incident on one of the led monitor like this.
https://www.badcaps.net/forum/troubl...lashing-on-off
The monitor is HP 27es LED Monitor
https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
The monitor will randomly blackout and display no signal and will recover again.
Sometimes need to power and off again to restore the display but...-
by sew333My pc:
10850K stock 4800mhz stock Kraken X73 good temps
2x16 GB DDR4 GSKILL 3000mhz XMP
Seasonic Tx-850 Ultra Titanium
Gigabyte Rtx 3090 Gaming OC
Aorus Z490 Pro Gaming
1 TB SSD
4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
Power... -
by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... - Loading...
