e-machine no signal
  • davg
    • Sep 2008
    • 536
    e-machine no signal
    Hi all I would like to thank the contributors on this site for the valuable information and the help I have received I have fixed several monitors from the info you guys have given and mostly was replacing bad caps. I will continue to use this site, keep up the good work. Here is one I can`t seem to find I am checking out a lcd monitor for a friend. It is a e-Machine brand. When I plug it in and fire it up the light is green than it shows a no signal on the screen than goes black and the light goes amber. The monitor cable is properly attached and working ok on another monitor that I have tried so it is not the video card on the pc. What should I look for inside the monitor. Would this be on the video board or the inverter board. All cabs seem good.
  • EGuevarae
    • Nov 2008
    • 1336
    Re: e-machine no signal
    I had a similar problem with an eMachines E15t3G. It was one (well, three...) bad wires inside the VGA/Signal cable. Check those with a multimeter. If they are OK, then the problem will be in the Video Board.
    Eduardo
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • Windows 10 Pro x64
    • GeForce GT1050
    • davg
      • Sep 2008
      • 536
      Eduardo
      Thanks eguevarae I changed out the cable and still the same. I will check out the board. Is there something common on the board that could cause this problem? What do I look out for?
      • EGuevarae
        • Nov 2008
        • 1336
        Did you solve this? I have received a dead eMachines e15t3g. Is this the same model as yours?
        • GeForce GT1050
        • sew333
          Pc shutdown, monitor flickered with no signal after 10 seconds
          by sew333
          My pc:
          10850K stock 4800mhz stock Kraken X73 good temps
          2x16 GB DDR4 GSKILL 3000mhz XMP
          Seasonic Tx-850 Ultra Titanium
          Gigabyte Rtx 3090 Gaming OC
          Aorus Z490 Pro Gaming
          1 TB SSD
          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
          Power...
          02-22-2022, 10:27 AM
          by momaka
          03-15-2023, 10:17 PM
        • AstutePauciloquent
          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
          by AstutePauciloquent
          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
          11-23-2023, 11:02 PM
        • Rick_1234
          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
          by Rick_1234
          Good evening, gentlemen.
          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
          https://drive.google.com/file/d/1L6S...ew?usp=sharing
          Things I tried
          - Bought a new AC adapter thinking that was the problem but the problem...
          06-22-2024, 04:44 PM
        • glutton4punishment
          Samsung monitor Installed 1 cap wrong, now menu button dead, "no signal detected" msg
          by glutton4punishment
          Samsung synchmaster 226BW.
          Before I replaced 5 caps, the screen was dim.
          Sometimes it wouldn't turn on.
          I opened it up, and found 4 bad caps in the pwr supply section.
          I unfortunately installee one backwards, i.e. wrong polarity.
          When I turned it on, I head a loud pop, and I quickly shut it off.
          The replaced caps are 3 860uF 25V's, and 1 330u 35V.
          One of the 860uF blew.
          I didn't have another 860uF at home, so I tried it with a 1000uF 35V cap (I remember the reading of the 1k uF cap was close...
          03-18-2023, 12:49 PM
