V7 D22W12 Monitor Color Issues
  • AutoMechanic
    • Mar 2017
    • 9
    Hey Badcaps, another question regarding my revived 22" monitor.
    Previously, I had a 2 seconds to black issue on a monitor I knew nothing else about.
    https://www.badcaps.net/forum/showthread.php?t=61415
    Here is the thread on that. I am a novice on board repair, and took the monitor apart, replaced the obviously failed cap, put 'er back together, and have been using it ever since.
    Very intermittently, and I can't find a pattern to why it happens, but the monitor will occasionally botch the colors. I get pinks and greens where they simply don't belong. The entire display just gets the colors wrong for a spell, then without any tweaking on my part, they'll go back to normal. I do always have a few vertical green pixelly lines on an all black screen. I account that to leaking LCDs?
    I'm not sure if there is any fixing this color confusion. Is this another symptom of junk caps? I only replaced one cap, the others appeared okay, and I don't have the knowledge/tooling to otherwise test the other caps. Is it possible recapping the whole board will fix this issue? It seems to be getting more frequent and obnoxious.
  • 1supertech
    • Apr 2012
    • 384
    Re: V7 D22W12 Monitor Color Issues
    Sound like a dirty LVDS cable, go back in replace all capacitors and clean LVDS cable with alcohol.
    • AutoMechanic
      • Mar 2017
      • 9
      Huge thanks 1supertech, my display is 100% perfect now. The vertical lines I thought might be dead LCDs are cured too. Those lines were present prior when the colors were good or bad. No color issues thus far, the color doesn't need to be tweaked in the LCD Menu buttons any more, and those lines are gone.
      While it looks like the ribbon going to the LCD was attached, the one side tang/hook wasn't clicked into place. I removed the ribbon, cleaned it with alcohol and reattached it making sure that the hook clicked. It took surprising force with a screw driver to make that happen, and while the ribbon does not appear to be any more engaged than before, the LCD is flawless so far. Thank you sir!
      • 1supertech
        • Apr 2012
        • 384
        Glad it worked out for you.
          by momaka
          03-15-2023, 10:17 PM
        • reessi
          ACER BM320 Monitor - Horizonal Flickering Lines After a While
          by reessi
          The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
          They are black on the right and gradually fade to nothing on the far left.
          They start either after 5 mins or up to 2 hours after so annoying for testing.
          They flicker continuously very fast! With a slight pause milli-second every second.
          Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
          I tested each half by removing the first the left flex from...
          06-03-2025, 09:58 AM
        • Kikerumbo
          Mi Curved Gaming Monitor 34" - Horizontal lines
          by Kikerumbo
          Thanks in advance for any help you can provide.
          I have a Mi Curved Gaming Monitor 34". A few weeks ago it started to show (or not showing) horizontal lines. Of course, it's outside of the warranty period.
          After some hours of reading and watching videos I disassembled the monitor and checked the ribbons that go from the TCON board to the panel PCB. If I disconnect the ribbon for the right side of the panel, the other half shows a perfect image. I ordered a "new" TCON, installed it and the issue persists so that tells me it must...
          03-14-2024, 02:48 PM
        • Jesus Coder
          Issues Reviving Old Dell 2408WFPb Monitor
          by Jesus Coder
          I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
          06-25-2023, 02:33 PM
        • valscu
          EIZO SW3031W monitor blue color instead of black
          by valscu
          I have an Eizo SX3031W monitor and after a period i had problems with the tcon board. I did reflow, it went well for a while after but the problems appeared again. The second reflow attempt was a failure, the tcon board stopped working. In the meantime, I bought a perfectly functional Samsung 305T monitor from which I took the tcon board and installed it in the Eizo monitor. Since I turned on the monitor, the blue color appeared in the background instead of black. And also in Windows, appears blue instead of black. I tried various settings from the monitor and driver settings but...
          08-10-2022, 02:08 PM
