Dell 2408wfp no image
  • rocket
    • Oct 2013
    • 10
    Just came into possession of this monitor. When powered on and connected (to a PC on DVI) I only get an empty screen.
    The backlight is working and so is the PIP function but no image is displayed at all, not even the input indicator icon that normally appears on the top left. Pressing the menu button similarly has no effect. Also while in this state it may take a few presses of the power button to turn the monitor off.
    Before I crack it open - any general thoughts? From what I gather it appears likely to be a tcon issue.
  • Rainbow
    • Aug 2005
    • 1375
    I've got 2408WFPb with the same problem. Backlight comes on, power LED is green but the screen is blank. No OSD.
    The voltages on T-con seem to OK (1.8V at IC19, 3.3V at IC21, 2.5V at IC7 & IC9, 15.15V at CC20..CC24).
    The delay when turning off is also present - it might indicate a problem on the main board (unless the T-con communication is bi-directional).
    • Borse2008
      by Borse2008
      • There’s
      07-15-2025, 04:55 AM
    • andrhouseolly
      Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
      by andrhouseolly
      Hi.
      I kindly ask you to help me solve the problem.
      Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
      The board turns on, there is no image.
      Read more. When the power supply is connected, the front panel indicators light up briefly.
      When you press the power button, the button indicator lights up. The board works
      there is no image, there is no matrix initialization, there is no image on HDMI.
      When turned on, the fans do not spin, but when they warm up they start spinning.
      When you turn off the button, the fans spin up to full speed for a short...
      05-11-2024, 03:14 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
      by momaka
      03-15-2023, 10:17 PM
