Hanns-G HV-191D (mod: HV191DP)
This topic is closed.
  • pukh
    • Mar 2017
    • 12
    • Ukraine
    Hello.
    Monitor Hanns-G HV-191D (mod: HV191DP) after replacing all the capacitors the working capacity of the power supply and inverter is restored.
    The screen now shows vertical stripes of green color and in the middle the inscription "Input signal from of range"
  • 1supertech
    • Apr 2012
    • 384
    Re: Hanns-G HV-191D (mod: HV191DP)
    Out of range could be screen resolution is too high vertical line dirty LVDS cable or bad panel.
    • pukh
      • Mar 2017
      • 12
      • Ukraine
      OK!
      Tomorrow I'll try to flush the connector and check with a low resolution from the video card
      • pukh
        • Mar 2017
        • 12
        • Ukraine
        The monitor gives a picture (desktop Win 7) only through DVI!
        While in the picture the screen is filled with green stripes and the image is doubled (it has several reflections as when receiving a re-reflected analog TV signal).
        On other forums I subtracted the need to replace the memory chip ...
        I do not know what can replace the memory in this situation.
        • pukh
          • Mar 2017
          • 12
          • Ukraine
          The monitor is restored.
          To all who helped with advice-THANK YOU!
          I ask the moderator to close the topic.
          • Petros_Z
            Led stripes for Toshiba TV 32W1433DG
            by Petros_Z
            Hello, I have the TV of the title and it has problem with the led stripes. The code of the stripes is VES315WNDA-01. Also on the chassis there is a code "Model VES315WNDS-01". Searching for spare parts I found that there are led stripes for each of those codes. I don't know if someone had changed them before. Based on what code should I order the spare parts? From led stripes or chassis?
            Thanks in advance and sorry for my bad English.
            04-02-2024, 02:59 AM
          • kotel studios
            Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
            by kotel studios
            Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
            In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
            08-06-2025, 02:07 AM
          • halen
            Hisense H55U7B vertical stripes
            by halen
            I have Hisense H55U7B TV with no picture, only big vertical stripes. I did several tests and I'm not sure, where is problem.
            1. Connected tcon to 12V, white, red, green, blue, black picture visible in cycle on full LCD without error
            2. Connected only left side of LCD to tcon, big stripes
            3. Connected only right side of tcon, visible normal picture on the right. Working as expected.
            Where could be problem?
            Tcon RSAG7.820.7932/ROH
            Main board RSAG7.820.8698/ROH
            Jan
            06-18-2025, 03:58 AM
          • abhorsen
            Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
            by abhorsen
            Hey guys,
            Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
            Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
            Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
            07-06-2023, 10:22 AM
          • ttmi100x
            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
            by ttmi100x
            Greetings everyone,
            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
            Upon closer inspection...
            07-31-2024, 06:36 PM
