Hanns-G HV-191D (mod: HV191DP)
This topic is closed.
    Hello.
    Monitor Hanns-G HV-191D (mod: HV191DP) after replacing all the capacitors the working capacity of the power supply and inverter is restored.
    The screen now shows vertical stripes of green color and in the middle the inscription "Input signal from of range"
    Re: Hanns-G HV-191D (mod: HV191DP)
    Out of range could be screen resolution is too high vertical line dirty LVDS cable or bad panel.
      OK!
      Tomorrow I'll try to flush the connector and check with a low resolution from the video card
        The monitor gives a picture (desktop Win 7) only through DVI!
        While in the picture the screen is filled with green stripes and the image is doubled (it has several reflections as when receiving a re-reflected analog TV signal).
        On other forums I subtracted the need to replace the memory chip ...
        I do not know what can replace the memory in this situation.
          The monitor is restored.
          To all who helped with advice-THANK YOU!
          I ask the moderator to close the topic.
