HP 23xi Left half pixelated and pinkish
  • DevPre
    • Apr 2017
    • Italy
    Hi guys, i'm having some problems with this IPS monitor. The left half of it has some color issues and appears pixelated, not focused. If i keep a browser tab open for some time i can see its shade even if i close it. What do you think? Is the panel gone or it's a lvds problem? I cracked it open and cleaned its pins with some isopropyl alcohol but it didnt helped.
    I'll link some pictures below:
    Link to the Imgur album: Click here.
    Thanks for the help, i really appreciate it. Oh, yeah, and sorry for the grammar mistakes i'm not a native speaker. Please let me know if i made some so i can improve my language skills.
  • DevPre
    • Apr 2017
    • Italy
    Re: HP 23xi Left half pixelated and pinkish
    I teared it down another time, i put the board in a alcohol bath and examined it carefully. Seems ok, i teared down even the lcd panel and the backlight is ok too. I moved a little the lvds flex cable and i think it's fine too. I think the lcd panel is faulty, but i'm not going to replace it since it's not worth it.
    • Raulnn
      TD Systems K50DLG12US half black and half white screen
      by Raulnn
      good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
      By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
      01-20-2024, 04:49 PM
    • scubacamper
      Sharp Aquos LC-70C6400U Half Screen Dark
      by scubacamper
      I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
      Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
      when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
      05-03-2025, 12:19 PM
    • valvashon
      LG 55UH6150- trouble powering up, then half lit screen (pictures!)
      by valvashon
      The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
      Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
      11-24-2024, 12:08 PM
    • smic717394
      MSI Optix MPG27CQ half screen working. Identify burned component
      by smic717394
      I have a MSI Optix MPG27CQ screen to fix, only half screen is working, I found a burned chip on the right buffer board (S270DP01V00_HF_SR) but I can't read the model. Can anybody help?...
      04-08-2025, 05:53 AM
    • bbruzzoni
      65" W Box TV half backlight problem
      by bbruzzoni
      I have a 65" W Box TV, model 0E-65LED4K that most of the times it is turned on, the right half of the backlights flash on and off in a split second and remain off while the other half lights up and stays on just fine. I thought it would be the LEDs, so I checked all of them and they're all good, no direct problem with any of the LEDs or any of the connections. One thing I noticed was that when I disconnected one of the LED strips from the left side (the working side) the backlights now switched and the half left side flashed and stayed off while the right side lit up and stayed on. I then...
      05-22-2021, 11:25 AM
