What are these white patches on top of the metal parts of this board?
  • darran
    • Oct 2016
    • 24
    There are these white fairly dense patches on top of the metal parts of the power supply. Does anyone know their purpose?
    Thank you!
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: What are these white patches on top of the metal parts of this board?
    look like stick on cooling pads ..but only ones i have seen are black
    • BadCon
      • Jan 2017
      • 16
      • Croatia
      I'm seeing just two of them.
      And thats thermal pads for sure.
      Pretty common in laptops to transfer heat from chipset/vrm/vram.
      I have seen them mostly in white color, but also blue (Arctic thermal pads).
      • darran
        • Oct 2016
        • 24
        I reckon that is what they are. Thank you!
        • R_J
          • 9535
          If the tv has a metal rear cover it could be to isolate the hot side of the power supply from touching the rear cover.
          • BadCon
            • Jan 2017
            • 16
            • Croatia
            AFAIK, actually opposite of what you wrote. Its like thin thermal pads between TO-220 and heatsinks which transfer heat and not electricity, just thicker.
            Thermal pads transfer heat from small surface, onto bigger surfaces like metal shield in LCD monitors, to offer better cooling. On small passive-cooled netbooks, thermal pads are often used to transfer heat from processor and chipset to metal plate under keyboard.
            If LCD housing is metal, and manufacturers doesnt wanted to conduct heat from internal cooling, they wont be using anything, just a air gap between housing and hot metal parts inside or use sponge with coated tape which is heat-resistive and doesnt transfer heat (Im unable to find pic of what I mean, but if you're disassembled some notebooks before you surely know what I mean).
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4325
              • Italy - Milan
              Where is the problem? if factory has put it in there's a motivation...
              • R_J
                • 9535
                No your wrong, if the heatsink under the gap filler pad is hot (connected to one side of line voltage) and it comes in contact with the rear cover it makes the whole tv rear cover hot and will give a someone a shock or worse. It could also help with heat transfer I suppose.
                Check the ac voltage between cold chassis ground and the heatsink under the pads and see what voltage you get, If its 0 volts then I guess its just for heat transfer if its around 50 volts or more I would lean more to isolation, manufactures will use whatever they have at the time of manufacture
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4953
                  • New Zealand
                  Edit: Never mind.
                  -David VanHorn
                  • darran
                    • Oct 2016
                    • 24
                    These patches are on one of my monitors and they do separate the metal part of the heatsink from touching metal. The 3rd patch was in the picture but I removed it to show what was under it.
                    On one of the monitors I have which is in the same model they used black plastic on the inside of the metal cover and didn't use white patches. This black plastic separates the metal part from touching the metal cover.
                    • darran
                      • Oct 2016
                      • 24
                      They could also serve two functions! Everyone could be right!
                      • jiroy
                        • Jun 2016
                        • 2416
                        • Lebanon
                        The way i see it , they serve the two ways , isolating and cooling at the same time .
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
                        • dmcabs
                          SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
                          by dmcabs
                          Hey guys,
                          I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
                          This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
                          FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
                          I'm a bit rusty but still have ability to dig right down.
                          I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about...
                          09-21-2024, 11:09 AM
                          MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                          This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-06-2024, 07:46 AM
                          MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                          This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                          09-06-2024, 07:29 AM
                          MSI Prestige P65 8RF-457BE Creator White Notebook P Specification for Upgrade or Repair
                          This specification for the MSI Prestige P65 8RF-457BE Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-457BE Creator White boardview and P65 8RF-457BE Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-06-2024, 07:25 AM
