Liteon pa-4151-1-lf, dell 3007 power supply
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    03-31-2024, 02:12 PM
  • Info13
    Dell H235P-00 Power Supply Failure
    by Info13
    A H235P-00 power supply unit from a Dell Optiplex 760 PC is faulty.
    After removing it from the computer, I placed a paper clip between the green and black wires, then connected it unloaded to the mains through a series lamp.
    ➡️ First test:
    The PSU partially works: the green indicator LED lights up, and the fan starts for one second, then stops.
    A click can be heard at the moment it stops. The series lamp lights up when the power supply starts, then turns off when it shuts down.
    I then followed the advice from the forum and replaced...
    10-22-2025, 01:52 PM
    07-01-2024, 06:34 AM
  • Akhlz001
    by Akhlz001
    09-20-2025, 07:15 PM
