Six Acer V173 LCD monitor all with same problem, only display Win 98 640res
    Re: Six Acer V173 LCD monitor all with same problem, only display Win 98 640res
    Originally posted by Aeridyne
    U101 is
    A1
    AS1117L-33
    B0815 D1
    it measures, with black lead on top "fat" tab, from left to right
    3.2V / 0 / 1.8
    FAT TAB is not GND, that fat tab and the center pin are connected together internally and they are OUTPUT pin.
    You need to use circuit GND such as GND pin of the connector.
    It is 3.3V fixed LDO regulator 1117 series IC, so if you look at the device with the tab up: Left pin is GND, Center pin is OUTPUT (should show 3.3 VDC), Right pin is INPUT (should show 5 Vdc)
    • Aeridyne
      • Jan 2017
      • 21
      sorry, I don't know how to delete, I refreshed the page multiple times but I didn't see your reply until I had posted, I will check it according to the new information you have provided.
      • Aeridyne
        • Jan 2017
        • 21
        It seems to be working. Measuring with orientation as the fat tab north & the black lead on the left leg (ground), the right most tab shows 4.97V and the center pin and the fat tab / output both show 3.27V
          Yes, it is good and the output is within spec. More in-depth troubleshooting of the main board is required. may have corrupt firmware, etc.
          • Aeridyne
            • Jan 2017
            • 21
            Ok. Not sure how to go further in depth myself. That V reg was as far as I had gotten.
              Did you try heating the main/logic board with hair dryer for 2~3 minutes first and then power it up to see what happen, and also cooling it using canned air duster upside down?
              BTW, since the monitor has VGA and DVI, when try using either of them, it does the same problem?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4302
                • Italy - Milan
                #27
                Hi Aeridyne, i suggest you to find the program Moninfo from EnTech Taiwan, use it on a pc with first a good monitor, to be able to open the prog., then attach a faulty one and do a grab command to the prog, so it reads EDID data from the monitors, i suspect that those series of monitors has edid eeproms prone to fail.. find the way you want to pubblish the result screens of the prog, so we can see them. Try with all the monitors you have if you want, especially if you see garbled / suspecting data..
                • Aeridyne
                  • Jan 2017
                  • 21
                  I will try those three suggestions and post back soon. Knee deep in a home movie project for someone atm.
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    #29
                    nailed it.if you have one that works 100% clone eeprom.
                    • Aeridyne
                      • Jan 2017
                      • 21
                      Well, in conclusion here, it seems the issue was actually the backlights all along. If I took good working backlights from other stuff and plugged them in to either of the test boards I had they would stay on. Not having any way to purchase backlights for them all I gave up actually repairing them, but I feel I did figure out the real problem.
                        But does not make any senses since the backlights are just the light source it could not careless if the monitor is connected the PC with 98 640 res or not. It sounds like the provided DATA is wrong.
                        Post#1:
                        "The curious exception to this, is if I connect one to a Windows 98 system set to 640x480 display. They will usually display this. Not always but usually. I can disconnect and reconnect the VGA and it will usually come up and display and stay on. Not always, usually. I've gotten one to display an XP system and stay on once, and flash quickly a few times, but almost always it does nothing."
                        • svagi
                          • May 2020
                          • Czech Republic
                          #32
                          Hi, I have very similar symptoms on my Acer v173. When without signal is showing ACER logo and after that "no signal" information. When I connect VGA cable from the laptop it stays in the black screen with blue LED on, or the monitor is resetting with approx 3-4 s orange LED to blue LED light. I tested also BIOS mode for lower resolution but this no helped.
                          • 1fg52
                            • Apr 2021
                            • 6
                            • Colombia
                            #33
                            I have another faulty V173 showing Acer logo. Is like the MCU find every VGA signal as incomplete and went to a "parking" mode turning off backlights. I dissasembled the panel to see if there is an image without backlight but the LCD appears turned off completely.
                            I found a Service manual for a very similar monitor (same control board) and there is no hope: "No Image" troubleshooting end very fast with "change scaler and mcu" RTD2120L and RTD2025
                            https://www.manualslib.com/manual/23...page=35#manual
                            This fault is so pervasive and have same symptomps clearly these realtek chips had a point of failure.
                              by momaka
                              03-15-2023, 10:17 PM
                            • maralexbar
                              How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
                              by maralexbar
                              I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
                              It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
                              If anyone knows how to force the external monitor as primary for Notebooks of those models
                              11-02-2024, 09:18 AM
                              09-06-2024, 05:27 AM
                              Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                              This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                              09-07-2024, 05:00 AM
                              Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                              This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
