sorry 4 being greedy but... another patient samsung245B plus
  • masterbateson
    • Jul 2016
    • 42
    Sorry to drop a few on you guys at once but here is another I thought potential easy fix I got from Eblag.
    I thought i might be able to get myself a bigger monitor on the cheap.
    So far no luck.
    This Monkey is another samsung(do you see a pattern emerging or is it just me??)
    its a Model?245Bplus or model code LS24hubcbl/edc or type HU24BS
    Set appears to be dead/ no back light etc
    PSu fuses ok not blown, no bulging caps visible, not tappable, a solder up did nothing.
    Any tips/ideas would be great. PSU is a dong yang BN44-00195A
    I have cleaned up the board and scraped off the Brown old glue stuff as suggested in another thread somewhere.
    But the Patient is still flat lining /dead/in a coma.
    Any help would be greatfully received.
    Wondering whether to just blanket swap a load of caps or wondering if its summat else?
    Ta
    Paul B
  • cpt.charlie
    • Sep 2013
    • 270
    • Spain
    Re: sorry 4 being greedy but... another patient samsung245B plus
    Post a good quallity photo of the board and start measuring the output voltages.
    • 1supertech
      • Apr 2012
      • 384
      Their are 3 68 ohm resistors close together near a serial number on power supply test and replace.
      • masterbateson
        • Jul 2016
        • 42
        Thanks Supertech thats a great place for me to start!
        All you guys are a lot more current in testing fault finding and working on stuff.
        I am more than a little bit rusty, last field service job i just left after 10 years i dont think i broke a meter out more than twice and def could count on one hand
        It seems that the power supplies these days are somewhat different from the old CRT days.
        Do sets not trip any more/tripping, with the old TV's if a switch mode PSU had failed you could here it clicking, doesnt seem to happen any more?
        Also in old days you used to be able to disconnect the Psu from line output stage and wang a 60w bulb for instance on the 100 odd volt line to load the Psu while testing.
        Seems like you dont do that any more.
        P.s. with these modern tellys/monitors, if the set is giving symptoms like its dead, but you do have something as in a flashing standby LED is it safe to assume the PSU is shutting down for some reason? and If so Am i likely to get/have any outputs?
        Ta for replies guys, i will get picks up today, and break meter out and check those resistors.
        Would be great if its them.
        • re-atari
          • Oct 2010
          • 136
          Sadly not on this one. The 3 failing 68R resistors are only present on the 137A PSU used in 245B's.
          The OP has a 245B Plus monitor with the much dreaded 195A PSU. He might consider buying a used 137A PSU, as they are much easier to fix when failing. On these usually only one of the 3 68R resistors fails (goes open circuit).
          I have successfully fixed several 137A PSU's in the past years, whereas my success rate with fixing 195A's is exactly zero.
          re-atari
            You said no backlights, but do you at least have the standby 5V Voltage?
            • masterbateson
              • Jul 2016
              • 42
              Mr Atari is exactly right, there is deffo no three resistors on this one. here is a piccy or 2.
              I will pop board back in the set and get the meter out and test some voltages.
              Anyone got a circuit diagram for this set?
              I suppose i could always get one of these other PSU boards if i can find one, and if they are interchangeable.
                What are the numbers on the barcode sticker?
                That is not BN44-00195A.
                BTW, what is that bare wire soldered on the bottom side of the board? It looks like the bottom side soldering works need to be cleaned up and inspected.
                • masterbateson
                  • Jul 2016
                  • 42
                  The wire is just a cap i replaced, as mentioned earlier in post, the print lifted a little so just to be on the safe side i soldered the cap leg to the next cap along on the same rail/track.
                  Yup its not had a clean yet, and will be made to look more pretty/proper job before i put the board back,
                  That is if its going back in,
                  • masterbateson
                    • Jul 2016
                    • 42
                    Serial number sticker as far as I can tell(could hardly read as so small) was/is
                    cn07bn440050ask28d7e2621 the a in ask could be a four as print is smudged.
                    • masterbateson
                      • Jul 2016
                      • 42
                      What a jack ass! I posted wrong pics in the wrong posts and i cant seem to edit my above post with the pics.
                      The PSU out of this monitor is in fact this one.
                      http://i1081.photobucket.com/albums/...psqwydeovv.jpg
                        So are you at least getting any standby Voltage?
                        • masterbateson
                          • Jul 2016
                          • 42
                          I will have to lob it back in the set to check, or can you test this out of the set?
                          Struggling with time at the mo, but hopefully get a chance tonight.
                          A quick dummy question, but are standby voltages usually 5v or 12v these days?
                            You can run the board by itself to check the standby Voltage without having another boards connected to it, just have to be real careful not to touch anything in the primary side with your body/hands.
                            • masterbateson
                              • Jul 2016
                              • 42
                              well just having a quick poke around and seems like ive got nothing on anything on the secondary side just ikkle Mv's. def no 5v or 12v on anything.
                              240 going in, both fuses intact, bridge reccy is fine, thats as far as Im up2 so far.
                                Then we need to find out if we have about 330VDC between the two legs of the main filter cap or not.
                                • masterbateson
                                  • Jul 2016
                                  • 42
                                  we do indeed bud
                                  • masterbateson
                                    • Jul 2016
                                    • 42
                                    if i have the psu switched on live and connected to the main board, and then measure the standby voltage its jumping around mostly around 3- 3.5 v (all over the place really looks for a fraction of a sec its at 5v but its def not stable.
                                    • cpt.charlie
                                      • Sep 2013
                                      • 270
                                      • Spain
                                      Maybe your main board is taking too much power due a shorted component, check for any overheating component, specially linear regulators, however i would check the PSU without anything connected to it, 5Vsb should be stable in that case.
                                      If you have a lab PSU try to feed 5V on the main board to determine if the board is taking excesive current.
                                        At least we know that you do have DC on the main filter cap otherwise you will not see any DC at the output connector at all. I thought you said you do not have any DC on post #15.
                                        It is confusing when the information is not clear.
                                        Is the 5V steady if you do not have the main board connected it?
                                        • Hobb7t
                                          Asus ux510u Just trying to make sure,that my decisions seem right or not!
                                          by Hobb7t
                                          Greetings fellow forumers.
                                          The reason i'm writing this post, is to find some people who have more experience than me on electronics repair. The last month i've been dealing with an Asus laptop (ux510u) that didn't let the charger's voltage pass through the first two MOSFETs. I manage for find some burned/shorted components and replace the parts (most probably the ones that got damaged by the short), but the last one seemed like a stone that im not feeling 100% confident that is creating the issue at all. I found a whole array of caps next to the CPU which seem shorted to ground...
                                          03-15-2023, 03:57 PM
                                        • Manabo
                                          MSI MAG Tomahawk B660 Power Cycling after BIOS Changes
                                          by Manabo
                                          Hello guys,
                                          I have a big issue, I think i just bricked my mobo.
                                          Last night I wanted to get a little more umph out of my pc, since I can not oc my 12400F decided to oc the ram , changed the frequency and got oc fail messages during boot, at 3700 it was stable tho, as I am a total noob when it comes to this i started googling settings, I saw people saying its better to run at xmp values but try to tidy the latencies a bit.
                                          Failures again, xmp automatically chose gear 2 I saw on forums that for ddr4 gear one is better, chose gear 1 at stock xmp...
                                          01-31-2023, 10:37 AM
                                        • brokemylaptop
                                          Predator Helios 300 Black Screen after repaste.
                                          by brokemylaptop
                                          Hello everyone, hope you are all well and healthy, enjoying your weekends.
                                          I come to you with a very silly mess I made for myself trying to repaste my new (second hand) gaming laptop.
                                          The model is Predator Helios 300 by Acer, model nr: PH317-52-53KY
                                          I bought this laptop yesterday in really nice condition, working great. I played some cyberpunk and I noticed temperatures were quite high (90-95) so I decided to use some of the Thermal Grizzly Kryonaut paste I still have left from my old laptop to repaste it.
                                          I opened the laptop, at the same time...
                                          12-12-2020, 10:02 AM
                                        • LHLaurini
                                          Is it possible to recover a gamepad's firmware after accidentally erasing it?
                                          by LHLaurini
                                          Hi, there!
                                          I bricked a GameSir T1s (product page) gamepad while reverse engineering it by issuing random commands though Bluetooth LE. I have most likely accidentally erased or overwritten the firmware. Could I possibly recover it? (photos)
                                          What I know, currently:
                                          • It doesn't turn on. Only two LEDs light up while holding the HOME button. Also won't connect through neither the wireless dongle nor Bluetooth.
                                          • Connecting though USB is useless. The same two LEDs light up, but that's it. No USB connection is made (I made sure by watching kernel logs)
                                          • There
                                          10-06-2019, 02:43 PM
                                        • masterbateson
                                          Another sad Samsung, mates girlfriends telly
                                          by masterbateson
                                          My mate asked me if i could have a peep at his birds telly
                                          Its a samsung PS42C450 plasma jobby.
                                          Telly comes on fine, only prob is a horizontal row (looks like 1 pixel) wide missing/black.
                                          I think a replacement YB board may sort this out??? at least thats what i think the board in question is.
                                          Its got a ref model:42u2p-yb rev 1.3 pcb no lj41-08594a pba lj92-01739a
                                          I might be barking up the wrong tree here, but its the board with 6 ribbon/flat cables at side that seem to supply the panel with its video.
                                          If I unplug the ribbon cable...
                                          01-09-2017, 04:33 PM
