Dell 2007FPb problem
  • schnee
    • May 2016
    • 13
    • Hungary
    this is my 1st real post on this forum. :-)
    My son has a Dell 2007FPb monitor, whic a few weeks ago started to act oddly: it was woring for a 30-40 minutesm, then turned off. It was possible to turn it on with unpluging and replugging the mains cable. A few days later is stopped working.
    I had no time till now to look into the device. Thanks to threads on this forum i was able to repair the power supply on the USB board (i had to replace a small resistor which was out of spec - 47 kOhm). So now the monitor has power, recognized by the computer, but screen stays empty - no osd, no data displayed from the computer.
    I checked, based on the threads the following voltages:
    Main power:
    - 19 VDC - OK
    USB board:
    - 3.3 VDC - OK
    - 5.0 VDC - OK
    - 12 VDC - Not OK, but it is only for the sound barm which i do not have
    Logic board:
    - 3.3 VDC - OK
    - 2.4 VDC - OK
    - 1.8 VDC - OK
    LCD control board:
    - 19 VDC - OK
    - 3.3 VDC - OK
    - 1.8 VDC - OK
    I am bit lost now, where to look for the problem: the logic board seems to be OK, as power levels are OK and also the computer recognizes the monitor (and the monitor comes out from standby when attached to the computer). The LCD board was working fine before the problem occered and currently i was unable to identify any blown fuse or missing power in the card.
    I hope that somebody on this forum can give me some hint, direction to follow next.
    ps: I posted some picutres of the above boards too.
  • cpt.charlie
    • Sep 2013
    • 270
    • Spain
    Re: Dell 2007FPb problem
    Do you see any background image at the panel? Does the backlight turn on? Make sure you have connected properly the LVDS cable, move gently the cable while the monitor is working and look for changes.
    • schnee
      • May 2016
      • 13
      • Hungary
      I rechecked everything today. I do not see any background image on the panel. The backlight turns on. Monitor reacts on the front panel buttons, computer regnize it when plugged in etc.
      I tried to move the LVDC connectors on both ends, but nothing changed. I checked the cable with an ohm meter and all wires a good and did not find any shorts between pins.
      Do you have any other suggestions?
      • schnee
        • May 2016
        • 13
        • Hungary
        Found some documentation on the screen (LM201U05)https://dev.xdevs.com/attachments/do...2_final_1_.pdf and made some measurements on the control panel for the LCD. All measured voltages are in spec.
        • cpt.charlie
          • Sep 2013
          • 270
          • Spain
          You could check the sinal pairs, but you will need an oscilloscope.
          • schnee
            • May 2016
            • 13
            • Hungary
            Don't have access to oscilloscope unfortunately....
            Does any of these boards have a serial/debug output to connect them to a computer and see the output?
              • 31250
              i do see a space for a 4pin connector - pin4 is gnd.
              no idea what it's for though.
              • cpt.charlie
                • Sep 2013
                • 270
                • Spain
                maybe a bad solder joint?
                • schnee
                  • May 2016
                  • 13
                  • Hungary
                  Those pins are connecting to the main IC and definitelly looks like a serial port. Will try to find spec for the FLI-5961-LF before connectiing anything to the pins. Would really appreciate if someone could post the chip's datasheet, as a quick search did not show up results.
                    • 31250
                    page136
                    • schnee
                      • May 2016
                      • 13
                      • Hungary
                      page136
                      Thanks!
                      • keepread
                        Dell monitor PSU vs Dell laptop PSU
                        by keepread
                        Hi there!
                        Someone gave me their old monitor, it's Dell S2715ht.
                        The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                        Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                        Today, 04:45 PM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • Borse2008
                        Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                        by Borse2008
                        Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                        I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                        • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                        • There’s
                        07-15-2025, 04:55 AM
                        by momaka
                        03-15-2023, 10:17 PM
                      • Garret Matt.
                        DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
                        by Garret Matt.
                        I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
                        Thank you in advance for any assistance you can render.
                        Inductor In question. Buzzes like...
                        06-20-2025, 01:21 PM
