HANNS-G HG24DPB Startup Screen Problem
  • xrad
    IT Technician
    • Nov 2016
    • Ireland
    Hi Folks
    New here.
    I don't have much experience with displays mainly PC's Laptops etc.
    I have a HANNS-G HG24DPB with a strange problem.
    1) I disconnect the vga from the monitor while pc is on, or pc is turned off before the monitor which causes a problem with the monitor.
    If the above steps are carried out when I reconnect the vga while the monitor is on or I boot up the pc and then turn on the monitor it will take up to 2 hours for the display to show the vga pc image. During this time their is a light hissing noise a bit like caps charging and discharging.
    In other words if their is a live vga signal to the monitor the above happens.
    Monitor works fine when I turn it on before the pc so switched on (before the vga signal reaches the monitor).
    Could this be a vga card problem in the monitor?
    This was tested on 3 different pc's same results.
    Hope all that makes sense!!!!
    Regards,
    xrad
  • xrad
    IT Technician
    • Nov 2016
    • Ireland
    Re: HANNS-G HG24DPB Startup Screen Problem
    Ok I typed the above in a panic to simplify the giberish,
    If the PC is switched on before the monitor it stays black
    for about 2 hours with a light hissing noise then I eventually
    get the pc desktop picture.
    The monitor must be turned on before the pc so that the pc
    desktop image shows up on the monitor straight away as
    normal.
    Any ideas...
    • mmccomputer
      problem with replacing lcd screen
      by mmccomputer
      I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
      otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
      If anyone has any information on the subject...
      12-15-2024, 03:44 PM
    • BMCappelletti
      Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
      by BMCappelletti
      Hi everyone.
      Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
      Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
      Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
      02-18-2025, 12:22 PM
    • abajor
      A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
      by abajor
      Having this very weird issue.
      The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
      I swapped with a working screen from an A2141 waiting for parts.
      The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
      The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
      04-27-2024, 01:37 PM
    • Chrissygizmo
      Sony KD-55XG9505 lines on screen problem
      by Chrissygizmo
      Hello again everyone,
      This is my latest mission, to try getting this Sony tv back to normal working order…
      I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
      02-19-2025, 11:31 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
