Zalman ZM-M215W 3D Monitor - weird screen issue
  • Misterkeeks
    • Nov 2013
    • 74
    • America
    Picked up this broken 3D monitor for $3 - why not?
    I've never seen this type of issue before. On both DVI and VGA inputs, the majority of the screen is grayish. The top few millimeters of the screen have accurate colors. I can faintly see that it is sort of displaying an image on the grayish part, but the image is very faint, and there are many artifacts on the image.
    When I drag a window onto the screen, it takes several seconds to fade in. If I drag it off, it fades out over several seconds.
    Any idea if this is repairable? I've attached some images, including one of the desktop background that it should have.
  • boyebaran
    • Sep 2015
    • 247
    • iran
    Re: Zalman ZM-M215W 3D Monitor - weird screen issue
    Hi
    i think it is a panel issues .may open the monitor and take picture from logic board and t-con board?
    tnx
    • Misterkeeks
      • Nov 2013
      • 74
      • America
      Originally posted by boyebaran
      Hi
      tnx
      I have pictures of the logic board and the T-Con board. I'm surprised that the logic board and the panel seem off the shelf - I guess the only special part of this monitor is the polarized panel in front of the LCD.
      I'm curious why you think it is a panel issue? It seems like the panel might work - some parts display fine, albeit with a delay. In my uneducated opinion it seems like a T-Con issue- which probably will necessitate replacement of the panel. Anyway, here are the pictures. I might purchase a simple VGA to LVDS board off of eBay for kicks to see if it fixes the problem, as they are less than $5 from China. Or, I'll gut another LVDS monitor and use the logic board from that.
        • 31086
        you cant just gut another monitor,
        the controller has to be flashed with firmware to match the resolution and data width of the panel.
        the ones from china usually come with a link to download the firmwares.
        • Misterkeeks
          • Nov 2013
          • 74
          • America
          Do you know how to configure this particular kind:
          https://www.ebay.com/itm/272188011190 ?
          The back seems to show some sort of configuration of pins to short but I can't figure it out... Also not sure where the 5v input goes...
          • boyebaran
            • Sep 2015
            • 247
            • iran
            Hi
            may you check under T-con board for main voltage?there is some smd fuse.please check main voltage on T-con board(like as 5V or 3.3v).if u need more help pls take picture from under T-con board.
            • Misterkeeks
              • Nov 2013
              • 74
              • America
              I tested voltages on the T-CON board. There are many test points on this board, you can see them on the pictures in the third post in this thread.
              Here are the voltages:
              1. VDDG...28V
              2. VDDA...13V
              3. VEEG...-7V
              4. VDDD..3.3V
              5. ????....0V
              6. VEEG...-7V
              VCOM_C1: 5.51V
              OE1..........1.01V
              CLKV1.......1.64V
              STV1.........0.01V
              VDDG_FLK.20.3V
              STH_F1......0V
              XDON1.......3.3V
              LP1...........0.16V
              IPOL1.......1.65V
              Points FD0-FD19 all had voltages of 1.15-1.4V
              VCOM_C2...5.51V
              VDDG.........2V (I think I might have the incorrect value here. I will test again.)
              VEEG.........-7V
              VDOD_P.....3.3V
              VDDA........13.2V
              VDDA_P.....13.2V
              VDDD_S....3.3V
              VDDD_T1...3.3V
              STH_B1.....0V
              VR1.....12.58V
              VR2.....12.02V
              VR3.....9.9V
              VR4.....9.3V
              VR5.....8.91V
              VR6.....8.28V
              VR7.....7.12V
              VR8.....6.13V
              VR9.....4.97V
              VR10....4.1V
              VR11....3.63V
              VR12....3.01V
              VR13....0.86V
              VR14....0.30V
              BD0-BD14 ranged from 11.5V to 14V
              Let me know what you think of these voltages.
              • Misterkeeks
                • Nov 2013
                • 74
                • America
                Anyone have any ideas?
                • Misterkeeks
                  • Nov 2013
                  • 74
                  • America
                  Any ideas before I scrap this monitor?
                  I see a lot of google translated Russian forums say that the "matrix" is broken, does that mean the the lcd panel itself needs to be replaced, or is this still possibly the t-con board?
                  • DqMagetz
                    Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
                    by DqMagetz
                    Good day!
                    I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
                    Here are the voltage readings:
                    • Input – 19V (stable)
                    • +LCDVDD – 3.3V briefly, then drops to 0V
                    • EDP_HPD – 3.3V briefly, then drops to 0V
                    • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
                    • EC BKOFF# – 1.8V briefly, then drops to 0V
                    • PANEL_OD_EN – 0.3V
                    Is it possible that the EC chip is corrupted or damag...
                    07-12-2025, 09:37 PM
                  • turmix
                    AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                    by turmix
                    Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                    The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                    At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                    During another reassembly, I made a mistake, and...
                    01-29-2024, 03:48 AM
                  • wizard13
                    Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                    by wizard13
                    I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                    I have checked the forum and the available documentation but could not find a solution specific to my issue.
                    • Brand & Model: Dynabook Satellite Pro C50D-B-100
                    • Part Number (P/N): PYU13E-00C00PFR
                    • Serial Number (S/N): 22028896H
                    • System Configuration (SC): A1PYU13E1127
                    • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                    • Power Input: DC 19V –
                    02-28-2025, 02:43 AM
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • cloudy
                    HELP - Contrast/brightness issue with subtitles on screen
                    by cloudy
                    Hi everybody
                    Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
                    Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
                    Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
                    It occours both on ubuntu and windows...
                    01-01-2023, 05:12 PM
