ASUS VW220T power supply
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    the problem is that the monitor turns on,and then off ...
    the board AIP-0180 looks OK
    https://www.dropbox.com/s/2w59cfipn0...83511.jpg?dl=0
    Re: ASUS VW220T power supply
    Do you mean that the power LED goes off or it goes into standby? Or are you talking about the backlights come on and then go off?
    What DCV do you get at the white connector and the black connector on the right side of the board of your picture? There are labels for the pins but the picture is not clear enough to tell us what the pins are for.
    • nbdy
      • Aug 2015
      • 162
      • Croatia
      Goes to stanby,the black connector is :
      O/F - BL
      5.2V-5.2V
      GND - GND
      will measure tommorow,and the white connector is not used on this monitor
      GND
      GND
      +5V
      +5V
      • nbdy
        • Aug 2015
        • 162
        • Croatia
        Meassured the 5V it is always present (the board is alone without the diplay board)
          If 5V is always present then your power supply is OK because it is an always on power supply.
          You need to have all the boards connected, so what DCV do you have on the OF and BL pins?
          • nbdy
            • Aug 2015
            • 162
            • Croatia
            O/f - 0v
            bl - -5v
            With the display board
            O/F - 0V
            BL - 225mV
            the 5V is constant
            btw. this is the second time this happens,the first time I changed the power board,but it is a little expensive now for me
            Could I check the backlight with something
            OK the third check with all connected, the screen goes on then off,on and off and into standby
            the lamps go on/of,on/off and into standby
              BL with -5V is not correct, it should never be Negative Voltage.
              "OK the third check with all connected, the screen goes on then off,on and off and into standby
              the lamps go on/of,on/off and into standby"
              When it is cycling like this, is the 5V is still very stable?
              The main board sends the two command signals to turn on the backlights and Dimming control signal.
              The main key is to know for sure if the 5V is steady or not.
              I also need good clear pictures of the bottom side of the power supply/inverter board.
              • nbdy
                • Aug 2015
                • 162
                • Croatia
                OK,now with all on ...
                The O/F goes from 0-2.2-0V (2.2V is for 2-3 sec)
                BL is 220mV
                The 5V is constant ...
                There is a little noise like a flying bug
                https://www.dropbox.com/s/3cfldcsy7f...73654.jpg?dl=0
                https://www.dropbox.com/s/c280326k7m...73701.jpg?dl=0
                BTW.:changed the 0.33uF at the 220V line,all the same ...
                  That CX101 cap is safety cap for line filtering, the power supply board will work without it.
                  You can try force on the power supply/inverter board to verify if it is OK or not by disconnecting the main board from the power supply board first and then install 470~1K (1/4 will do) resistors, one between A and C, and another one between B and C, then power up the board and you should see the backlights come on and stay on as long as the AC power is being applied to the board.
                  • nbdy
                    • Aug 2015
                    • 162
                    • Croatia
                    Added a 1k resistor,the monitor goes to sleep (alone mode)
                    With a computer connected the monitor goes on,but without a picture
                    and yes the backlights stay on (tryed on a different screen)
                      With the added resistors for testing the power supply/inverter board, you must not have the main/logic board connected to the power supply/inverter board. if the backlights come on and stay on (you will not have pictures on the screen of course) then you know that your power supply/inverter board is OK.
                      Next, you will remove the resistors and then plug the main/logic board back in place, then disconnect the cable between the LCD panel and the main/logic board and see if you can turn on the monitor and the backlights will come on and stay on (and of course you will not see any pictures on the screen), notes: the monitor may go into standby mode so you should hook it up to running PC.
                      So far i would say that the power supply/inverter board is OK.
                      • nbdy
                        • Aug 2015
                        • 162
                        • Croatia
                        The backlights stay on with computer attached to main board ...
                        Without computer it goes to sleep
                        • nbdy
                          • Aug 2015
                          • 162
                          • Croatia
                          Tested now with another screen,and all works OK ...
                          With the old screen it goes to standby ...
                            So you have more than one of this monitor that you can swap the boards around? Sounds like you have bad screen.
                            • nbdy
                              • Aug 2015
                              • 162
                              • Croatia
                              Thx for all help,yep it is the screen ...
                              The other screen was left by some frend "you will need it sometime" ...
                              Now i know the screen is working ;-)
                              Could I try to change the lamps,or is it somthing else ???
                                by sam_sam_sam
                                03-31-2024, 02:12 PM
                              • GLISIT
                                by GLISIT
                                01-16-2025, 02:29 PM
                                by sam_sam_sam
                                07-01-2024, 06:34 AM
                              • JimBanville
                                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                by JimBanville
                                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                09-13-2023, 07:21 AM
