Acer AL1717A
  • ehrja
    • Mar 2016
    • 19
    • México
    Acer AL1717A
    Acer AL1717A
    This monitor was working great, it was working continually 8hrs at the office but now is having troubles the problem seems to be the back light.
    I do a control test and notice that when I turn on the monitor it does well but at the minute it seems to shutdown I also notice that the status leed still on and green. Using a torch lamp I can see the windows environment and I thought that it can be a bad cap, to be easy and because in that moment I don't have my cap ESR meter I change all the caps because they looks flat, no evidence of physical bad caps.
    I do the repair an test it with the same anomaly.
    I thought it could be a could join soldering and reheat almost all trohole joins, the testing throw the same results.
    What could be happening here, any idea?
  • Dumah Brazorf
    • Jun 2013
    • 179
    • Italy
    Re: Acer AL1717A
    It could be the inverter trasformer for the lamps or the lamps themself.
    Do you have any spare lamp to test the inverter?
    • ehrja
      • Mar 2016
      • 19
      • México
      Re: Acer AL1717A
      Yes I do have one spread, I'll test one by one and check what is going on, I also have a cfl lamp tester I'll chech the lamps in the lcd also.
      • ehrja
        • Mar 2016
        • 19
        • México
        Re: Acer AL1717A
        Hello I test already the 4 lamps in the monitor they are in groups of 2 wraped with shrink tube. 3 of them toun on White light, just one is blinking red dark color like a mini storm, is obvious that this one is damaged and I wonder if is possible to use only 3 of them and just leave the bad one disconnected?
        Could that damage other components like the inverter or the other lamp that is aside the bad one?
        • mikey5791
          • 521
          • Malaysia
          Re: Acer AL1717A
          Hi ehrja,
          I have experienced using two lamps out of four lamps in a Dell LCD monitor due to
          only having two lamps connector on a different version power board replacing a bad
          power board. The bad power board has four lamps connector.
          Surprisingly the new power board works but at a slightly dimmer
          screen which is still usable by adjusting the screen brightness to maximum.
          BTW, I am still using this monitor for the past three months with no issue whatsoever.
            Re: Acer AL1717A
            Originally posted by ehrja
            Hello I test already the 4 lamps in the monitor they are in groups of 2 wraped with shrink tube. 3 of them turn on White light, just one is blinking red dark color like a mini storm, is obvious that this one is damaged and I wonder if is possible to use only 3 of them and just leave the bad one disconnected?
            It depends on the protection circuit design, most will shutdown the inverter circuit if one of the lamp is not detected in the first 3 second when the startup Voltage is applied to the lamp but the lamp fails to conduct or not present, it is done that way so you will not have high Voltage sitting there without the load so it arcs over.
            • ehrja
              • Mar 2016
              • 19
              • México
              Re: Acer AL1717A
              OK I got it, actualy I remember a tutorial to bypass the security circuit adding tree big resistors in series to dummy load the lamp I do not remember the details.
              Fortunately I got an old monitor that is also bad but the LCD was ok same brand and size and also is compatible with the lamps and the video buss so I just change it, the monitor was working fine for about 30 minutes or so, actually the quality of the image was better, tomorrow I'll test it again a few hours.
              and post a picture
              • khelane
                test active pfc power with lamp test
                by khelane
                Hello
                I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                Is there a way...
                06-03-2025, 01:00 AM
                09-06-2024, 05:27 AM
                Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                09-07-2024, 05:00 AM
                Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-07-2024, 04:10 AM
