Laptop backlight help
  • PedroDaGr8
    • Oct 2006
    • 130
    I have a toshiba satellite a45. The backlight just stopped working today out of the blue. Is it possible for me to diagnose if it is the inverter or the tube itself? How would I go about doing that? Would posting pictures of the inverter help? I hope it is the inverter because that is relatively cheap. Any other info needed?
  • arneson
    • Sep 2005
    • 1267
    Re: Laptop backlight help
    Occasionally I will scarf a scanner off the curb, just to strip it and keep parts.
    I use the tubes as inverter testers, and the inverters as tube testers.
    Jim
      Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
      This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
      09-06-2024, 09:30 PM
    • giliy52480@degcos.com
      Surface laptop 4 1951 no disp backlight on
      by giliy52480@degcos.com
      This surface laptop had a backlight flickering. I put some heat on the edp socket and some capacitors around (I think cold solder occurred) the socket, but after some days the problem came back. Then, immediately after turning it on, the system firmware update appeared(black screen with bar ), and during the test(press hand on the socekt) for the edp connector, whether it was broken or not, the system turned off (because when press on camera socket the backlight is got ok) and finally, when it turned on, the backlight was on, but no disp. When I pressed the F4 key to go to the bios, the display...
      01-05-2025, 03:38 PM
    • RdeveLabs
      MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
      by RdeveLabs
      To all the members here...
      Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
      So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
      05-05-2025, 04:59 AM
      Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
      This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
      09-07-2024, 06:11 AM
