Samsung SyncMaster 594MG CRT
  • sabareeshchambayil
    • Jan 2016
    • India
    Before stating the problem, I know the danger related to CRT and it's better to replace old CRT monitor with newest Led LCD.
    And I have little knowledge in troubleshooting CRT displays.
    But I just want to repair this.
    This CRT Monitor is not used for almost 2 year and started using 2 weeks before and it's working fine till yesterday.
    Now the problem is at first power on with VGA cable not connected it's normal that is signal not found or cable not connected image is moving all over the screen.
    And if VGA cable is connected to PC the image is showing which is shifted to right side(always like that) and I can make it center using monitor control buttons on side, after that it's working for almost 45 to 60 minutes without problem and after that the screen goes dark for some seconds and comeback with left and right side squeezed to inside and a small portion of top and bottom out of screen or a very small image at the screen center with warm colour or blank screen.
    I have opened the monitor and after checking I found that most of electrolytic capacitors are bulged or with high ESR so I changed most of the capacitors with same value also checked the transistors(HOT etc) and still no change the same things happening.
    what might be the problem?
    Anybody Any Idea?
    One more thing after this if we turn off monitor using on/off button of monitor its turning off but no Turn on To make it on i need to unplug the main AC cord for 10 to 15 seconds and monitor ON with same condition that is shifted to right etc .
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
  • turmix
    AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
    by turmix
    Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
    The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
    At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
    During another reassembly, I made a mistake, and...
    01-29-2024, 03:48 AM
  • Chrissygizmo
    samsung galaxy ao2s very temperamental after screen replaced
    by Chrissygizmo
    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
    Ive eventually managed to get it on and working but it's very temperamental...
    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
    05-26-2024, 12:05 AM
  • JunkmanJimbo
    Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
    by JunkmanJimbo
    Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
    No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
    Please help. Thanks in advance!
    08-12-2025, 11:45 AM
  • Kiberge
    Samsung LH82QENELGC/EN Help needed - Static line on screen
    by Kiberge
    HI guys!
    I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
    I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
    the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
    This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
    04-22-2024, 11:28 AM
