AOC 2241sga on and off
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    Got an aoc monitor which goes on (shows the aoc logo), goes off,and then on showing the cable connection,and goes off
    the power board is 715g2892
    Replaced some caps,but still the same ...
    replaced the mosphet 2060 ...
    advices???
    thx
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    Re: AOC 2241sga on and off
    Here is the picture of the power supply
    https://www.dropbox.com/s/el7qln266d...B1%5D.jpg?dl=0
      master hoarder
      • May 2008
      • 12175
      Could also be bad capacitors on the logic/video board. Can you post some pictures of that as well?
      Also, which capacitors did you replace on the power board?
      • nbdy
        • Aug 2015
        • 162
        • Croatia
        https://www.dropbox.com/s/j7iakhlrln...B1%5D.jpg?dl=0
        this is the picture of the video board ...
        I replaced the c818,c804,c921,c920 they where looking bad ...
        I have doubt on ld7578 the power dispenser ??
        • nbdy
          • Aug 2015
          • 162
          • Croatia
          Ok, finaly the LD7576 came,replaced him,but now i got every 5-10 sec a picture,and then goes off
          Changed the 2050CT, any one to help
          • bohaboha
            Help Identifying a component and advices needed
            by bohaboha
            Advice on this: VPMS2GMB I found some but they don't have the same indications on the chipset
            Does it have to be exactly the same or is it enough that it is a VPMS2GMB
            Identification: this Ic Q80B-104HIP when I search with Q80B-104HIP I get results for :EN25Q80B-104HIP as you can see the first characters are not in the picture is :EN25Q80B-104HIP the right one ?
            the last mentioned are from a samsung mainboard BN41-02751B-000
            Now the last one ic from USB AMCAP DIGITAL MICROSCOPE is blown but you can almost see many signs but not all of them if you can assist with some identification...
            02-20-2025, 03:43 PM
          • pbig
            advices for repairing Sony Bravia 32EX600 after lightning strike
            by pbig
            hi everyone,
            my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
            On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
            - the 450V/150uF capacitor voltage when plugged is normal at 394V
            - from connector CN6150 (15 poles)
            STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
            06-28-2023, 02:43 AM
          • Blaszow
            Lenovo Thinkbook 14-IIL
            by Blaszow
            Hello everyone. I have problem most likely with bios because I found no shorts on motherboard, all voltages seem to be present, laptop keeps restarting, the fan spins for a while a then stops when it starts spining again the keyboard lights up and it happens over and over. I tried bioses from other topics and they didn't work.
            I tried to clean ME myself in my original bios but for some reason after cleaning ME, ME analyzer showed that bios is corrupted, still new to editing bios so I appreciate any help or advices.
            Name and model: Lenovo Thinkbook 14-IIL 20SL
            Serial number: LR0EHZVK...
            08-04-2025, 10:22 AM
          • Malva
            Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
            by Malva
            I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
            Mainboard model: EAX65684604
            PCB marking: EBT62954607
            SPI chip: Winbond W25X20CLNIG Problem description:
            Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
            After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
            • I bought another
            06-25-2025, 02:07 PM
          • modtool
            HP x360 Chromebook 14A-CA, DA00GIMB6H0 REV:H, flooded, restored, slow and stuck in tablet mode
            by modtool
            Dear colleagues,
            I've entered the repair of the chromebook machines just one month ago and I've found some significant differences from the classic laptops or macbooks, so I'm searching some advices.
            The owner of this chromebook gave it to me after it has been left flooded by water for almost a week, so chances of repair were not so high, the mainboard was oxidyzed in many spots but I made a nice cleaning, resoldering and component replaging work and now it is almost working.
            Among other things I've cleaned many spots from oxyds, reballed CPU, EMMC, EC, replaced...
            05-07-2025, 06:10 AM
