Dell 2405FPW blown transformer?
    replied
    Re: Dell 2405FPW blown transformer?
    Originally posted by ucdzombie
    Thank you. And yes that's the exact same pin that I tested. The reading is 0.005v.
    You will have to trace that pin 8 to see where it goes next, it should be connected to Voltage source through some kind of switched Transistor, this is where the hard part comes in, tracing the board.
  • ucdzombie
    replied
    Originally posted by budm
    Can you zoom in and take the pictures of the IC?
    See marked picture.
    replied
    See marked picture.
  • ucdzombie
    replied
    replied
  • ucdzombie
    replied
    Did you download the spec sheet of the IC? It will tell you where pin 1 is and the rest the of the pins of the IC.
    I tried multiple sources. But the IC itself doesn't have any indentation or notch indicating the pin orientation. But by judging the orientation of the letters printed on the surface, I'm pretty sure I'm correct. Also I compared it with IC601, which has a couple of line indicating the orientation. Both IC have the exact same soldering style and pin number diagrams. So I'm assuming that's pin 8. In any case, IF this reading is what I got, does it indicate a bad IC?
    replied
  • ucdzombie
    replied
    Ok I just did some research and run the test (see picture, assuming I've identified pin 8 correctly), the voltage is very very small. On the scale of 0.1v, the multimeters needle barely moved about 3 clicks. Also I've noticed the surface of IC651 is somewhat melted. The part number is so faded and unrecognizable.
  • ucdzombie
    replied
    Ok, so I will solder a wire between the negative leg of 450v cap to the pin 8 of the vcc? But which pin is pin 8? And how do I check the voltage? Do I measure pin 8 in relation to the chassis ground? What scale should I be using?
    OK never mind. I think I understand what you meant. Solder the wire to pin 8 so I can test it easily without shorting other parts. Use the negative leg of the 450v cap as ground. Check the voltage of pin 8 in relation to the 450v neg leg. Am I correct? But which one is pin 8?
  • ucdzombie
    replied
    Originally posted by jetadm123
    There are different variations of this power supply. The 160 volts you are seeing should be boosted to approx. 390Vdc if the supply is working properly. I suggest you check the following:
    1) with power off, measure the resistance between pins of mosfet Q651 below. If it's the power supply I think it is, then Q651 (2SK3502) is mounted on the heatsink behind the yellow transformer.
    gate-->source
    source-->drain
    drain-->source
    You will see very low resistance if there is a short.
    2) is step 1 checks ok, then you will need to check the dc voltage of pin 8 (VCC) of IC651 (L6561) located underneath the board. It's the black 8-legged chip. Use the neg lead of the 450V cap for ground. You will probably have to solder a small wire to pin 8 and run it clear of the board to take your measurement. Be careful as you are working in a HIGH VOLTAGE area.
    replied
    So you DO have output Voltage from the power supply, not 0V like you have indicated in the post.
    If that is the case then you should have boosted Voltage close to 400VDC on the cap, all this time I thought you have no output Voltage from the power supply at all, but it is not the case but the Voltage is not 19'~20V like it should be, at this point you need to get the PFC boosted Voltage on the cap which will involve checking to see if the PFC Controller IC has DCV on the VCC pin for it to run.
  • ucdzombie
    replied
    Wait a minute, are you using the external power supply with the mod you made?
    If not then you cannot have 0V at all the pin of the power supply connector.
    I know some people use that buck converter module and run it from the power supply board, not from the external power supply.
    No. I'm sorry for the confusion. That mod is just to convert 19v to 5v since the original MOSFET was bad. As you know, I'm not an electrical engineer so I apologize again for my ignorance. So I've tried to test my board carefully again and I came up with more new readings hopefully to narrow down the problems. I've attached a picture to explain. Basically the mod (buck converter) is working properly by itself (converting 17v to 4v). However its source is only 17v, that means the power board is not working. And this is confirmed by testing the F701 fuse on the power board, which shows only 17v on both ends. In order words, the power board is not outputing 19v. Last time I fixed this monitor, the F701 fuse had 19v on both ends, so did the buck converter source.
    replied
  • jetadm123
    replied
    I do nor remember if the PFC is running all the time or not or only when it gets the PS-ON signal from the logic board, but at this point he indicate that there is no any DC from the connector at all so the it means there will there no VCC from the AUX winding of the power transformer to run the PFC circuit if I remember the circuit setup on this board. I cannot find my spare board yet.
    budm-I see your point. The problem now seems to be the mod that the OP did to the mainboard. Seems like the mod is putting out 17v, which is substituting for the normal 19v that the power supply would be putting out. Not really sure how to approach this type of mod.
  • ucdzombie
    replied
    Ok another update. I just checked the logic board. It has voltage reading. The mod I did 2 years ago (the little voltage converter in the middle of the picture) has a reading of 17 volt. So is this a bit low since it's supposed to be 19 volt?
  • ucdzombie
    replied
    gate-->source
    source-->drain
    drain-->source
    2) is step 1 checks ok, then you will need to check the dc voltage of pin 8 (VCC) of IC651 (L6561) located underneath the board. It's the black 8-legged chip. Use the neg lead of the 450V cap for ground. You will probably have to solder a small wire to pin 8 and run it clear of the board to take your measure ent. Be careful as you are working in a HIGH VOLTAGE area.
    Thank you. Ok I check the leads. They all have uniformal reading, which is 80k. I've attached a picture in case I'm reading it wrong. I was also curious about Q601 (which looks the same as Q651). It also has the same reading. Is this considered high or low resistance?
    replied
    gate-->source
    source-->drain
    drain-->source
  • jetadm123
    replied
    gate-->source
    source-->drain
    drain-->source
  • ucdzombie
    replied
    OK, since you are getting the 160VDC on the main cap, then no need to check the main fuse, etc.
    Right now we have Voltage to run the switching power supply but it is not active so we need to find out why next.
    I need to find the pictures of my power supply board so I can can give you the test points on the board to test next.
    BTW, you should get the Digital Multi Meter.
    Thank you. Would it help if I take a picture of of the bottom of my board?
    replied
