benq xl2411t
  • pringles
    • Mar 2016
    • 3
    • portugal
    benq xl2411t
    hello.
    so my monitor is doing this https://www.youtube.com/watch?v=BD-0XWsideE
    let me explain, first the monitor is at 85hz and it works but when i change it to 120 you can see that it displays image but has a snoww effect covering the monitor.
    at 100hz i can see the display but its full of lines and at 120/144 i cant seee anything.
    i opened the monitor i notice that two caps were a bit bigger then the rest, could that be thee cause?
    thanks
  • 1supertech
    • Apr 2012
    • 384
    Re: benq xl2411t
    Your monitor Vertical Refresh Rate‎ 100/120/144Hz‎ it's possible that your graphics card cannot handle refresh rate of 100 update drivers
    If capacitors are bloated on top or bottom that can be the problem.
    • pringles
      • Mar 2016
      • 3
      • portugal
      Re: benq xl2411t
      the monitor worked fine for two years, its not my gpu cause i tested with a new one.
      yeah two caps at least are a bit bigger on the top but nothing came out yet. its very strange, if i set 100hz i will have lines on the screen but if i increase the brightness with a program the lines disappear but at 120/144 it doesnt work.
      it something to do with voltage and backlight i think.
        by momaka
        03-15-2023, 10:17 PM
      • keepread
        Dell monitor PSU vs Dell laptop PSU
        by keepread
        Hi there!
        Someone gave me their old monitor, it's Dell S2715ht.
        The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
        Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
        10-30-2025, 04:45 PM
      • bembeno
        Benq T902DHA monitor turns off after 5 minutes
        by bembeno
        Benq T902DHA monitor when press power button its work good but turns off after 5 minutes ( power led off ) just when i plug any display source
        07-27-2024, 09:55 AM
      • wattage
        AOC AG493UCX 49-inch monitor - Firmware request
        by wattage
        Hello Badcaps Community,
        The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
        07-13-2025, 04:41 PM
      • ant3202
        HP 27es - LED monitor - Monitor Flashing On - Off
        by ant3202
        Hi Everyone
        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
        https://www.badcaps.net/forum/troubl...lashing-on-off
        The monitor is HP 27es LED Monitor
        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
        The monitor will randomly blackout and display no signal and will recover again.
        Sometimes need to power and off again to restore the display but...
        03-20-2025, 07:30 PM
