Samsung SyncMaster 204B
  • goldylocks
    • Mar 2016
    Hey guys,
    So I have a Samsung SyncMaster 204B that when plugged in the power light would flash on and off. I opened it up and sure enough there were 3 bad capacitors. I've replaced these capacitors and now the monitor when plugged in just has a solid power light. Pressing the power button doesn't seem to do anything. Any ideas where I should be looking next?
  • Chungalin
    • Jul 2014
    • 422
    • Spain
    Re: Samsung SyncMaster 204B
    Search Computer Displays subforum for "204B", there’re other threads dealing with this same monitor and I’ve seen at least one that could be your solution (clear EEPROM).
    • Lumberjack777
      • Dec 2010
      • 464
      Originally posted by goldylocks
      Hey guys,
      I'd open it back up and check all the cables, ribbons, and plugs. Chances are, something didn't get plugged back in.
      • goldylocks
        • Mar 2016
        Hi thanks for the replies. I've actually read those posts and tried clearing the EEPROM and nothing changes. All cables have been checked, haven't even put the monitor back together yet
        • Zeddenit
          • Mar 2016
          I have a similar issue with a Samsung Syncmaster 225BW. Monitor used to take forever to turn on like it had to be warmed up. I opened it up, saw 5 bad caps replaced them all and put it together now when I power it on the light stays solid blue but screen is black. Did the flashlight test and saw that there was a picture. Could it be that
          1) the capacitors I replaced are bad or one of them could be bad.
          2) Another component went bad such as the inverter on the screen
          3) could it be something else
          • ivtec
            • Dec 2008
            • 1967
            Hey guys,
            You also should re-solder some cold solders on power PSU,and also clean the hard glues too,i have a Samsung Sync-master 2493HM dead with blue led on that i fixed just by re-soldering and cleaning hard glues.
              09-07-2024, 05:50 AM
            • serious_electron
              Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
              by serious_electron
              Hello Everyone!
              I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
              06-28-2025, 02:57 PM
            • soopacrucial
              Samsung Syncmaster 740BF repair
              by soopacrucial
              Hi folks,
              I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
              Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
              10-29-2024, 02:40 PM
            • marcinq
              Samsung UE60KS7000 No Standby Light
              by marcinq
              I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
              I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
              05-26-2025, 11:36 AM
            • ChristianBr01
              LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
              by ChristianBr01
              I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
              The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
              What I already found is that the 12.8V are not an the connector to the main board connector to the power...
              04-23-2025, 01:48 AM
