Hann-G Hi221D - Flicker then black
  • wmansir
    • Jan 2016
    • 6
    Background:
    The monitor is from 2008, used 12+ hours a day. The monitor first had problems about 3 years ago. Once or twice a month it would just go black for a few seconds and then come back on. Until one day it didn't come back on. I could power cycle it and it would turn on for a few seconds and then go black. I don't recall it flickering before it went out, but it may have.
    After some googling and reading here I took it apart and noticed a popped cap. Having never done anything like this I figured I would gamble $5 that it was the problem so I ordered a replacement cap and replace it. It was surprisingly easy and it worked!
    Current Symptoms:
    A few months ago the same symptoms started up. Very rarely, blackness for a few seconds. Last week it went off for good. I can turn it on and if it is cold it works for a couple of minutes and then goes black. If I power cycle it after this it will stay on for 10-30 seconds, start flickering in brightness for several seconds and then black. Power light stays on the entire time.
    What I've done so far:
    I opened it up again and found another cap had popped. This time I ordered all the caps except the one I had already replaced. I hindsight perhaps I should have done that one too, but at the time I kind of assumed the problem was the old next to it that had popped and I was just replacing all the other old caps to avoid future issues.
    I replaced 4 Su'scon SG and one Samsox GK, with equivalent United Chem KZE caps. I also replaced 2 Su'scon SH (47uf, 25v, 125 deg C) with Rubicon RX30 (47uf, 50v, 130 c) because they were the closest high temp caps I could find.
    I didn't actually replace all the caps because I noticed that 5 I ordered were actually for the audio, which is and has never been used. I also didn't replace the large Su'scon 150uf 420v cap. (These are all in the bottom right corner in the first pic)
    After this was done I put it all back together and it seemed to work fine for 2 minutes, until it went black. The symptoms were unchanged. I have taken it apart again, inspected all the soldering joints, particularly my own, and they look good to my eye.
    I suspect it may also be the CCFLs. I popped off the bottom frame and one of the two lamps was pretty scorched at both ends. I don't know if that indicates a problem or not. (see second pic)
    I only have a multimeter for testing. I may be able to cannibalize a currently dead all-in-one PC for it's CCFLs for testing. Any advice is appreciated.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Hann-G Hi221D - Flicker then black
    Yes, that looks like a failed CCFL to me. You will need a spare on for testing.
    Plug in the good ones and the spare and power on the monitor. It should stay lit.
    • wmansir
      • Jan 2016
      • 6
      Actually getting the CCFL lights out of the AIO PC would have been a major pain so instead I was able to disconnect the lead and hook one up to the output from my monitor while leaving it in place.
      I played around with it a bit, and the burnt bulb is definitely on it's way out, dimmer than its partner and taking several seconds to get up to temp, plus the very tips glow red. Unfortunately, for diagnostic purposes, the monitor had a bit of a resurgence and even when put back in it's original state it wasn't flickering much even after an hour. Although if I cranked brightness all the way I did get a little flickering and it started making some noise. I didn't want to risk burning anything out so I'm waiting on the new CCFLs.
      I ordered a full set of CCFL lights in frames off ebay, from china so it will take a few weeks. Now I just have to look into the best way to take apart the top end of the frame, which contains the LCD connections.
      • wmansir
        • Jan 2016
        • 6
        UPDATE: CCFLs arrived today. Tested, installed and running for about 4 hours now with no issues.
        Well I have noticed some shading/uneven lighting around the top/bottom edge, but it's minor. The monitor has always had an issue with edge bleeding, so it may not be something new. Nothing I'm going to disassemble this thing again over.
        Like I said in my previous post, I ordered the replacement ccfls off ebay. $12 for the pair, (4 ccfls total) pre wired in frames. They were very similar to the old ones, fit perfectly, plugged right in. One difference is the new plugs aren't locking, which is good because those locking tabs are such a pain they probably cause more problems than they prevent. Took about 2.5 weeks. I was concerned about shipping damage but they were packaged very well.
        A lot of the domestic places I looked at didn't even have 22" frames in stock, and if they did it would have been 3-4x the price, even just the bulbs without wiring/frames would have been 2x for all 4. I'm hoping these last, but I'm sure they are all from china anyway.
        • sgcampion
          Asus rog strix scar 17 G733QR display Issue(flicker, black/white))
          by sgcampion
          My Asus laptop started flickering from time to time and more and more in last months. First the screen was going black but sometimes if I moved the screen it would work again, other times I needed to plug/unplug the laptop or close and open the lid to make it work again.
          In last days I see that if I move the laptop lid to about 45 degrees it will flicker or get white or black screen(it's random, sometimes white sometimes flickers etc). I was trying to troubleshoot it myself but seems like it's either the cable or the display....
          10-24-2023, 09:39 AM
        • ChIck3n
          Dell u2311h 20000 seconds to black issue
          by ChIck3n
          So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
          09-09-2024, 11:44 AM
        • fixit007
          Samsung flicker - BN44-00932T board or else?
          by fixit007
          I picked up this TV that the prior owner said - just died.
          Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
          Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
          Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
          05-04-2024, 06:14 PM
        • DrankinSAW
          LG 37LG5020 and the tale of 2 seconds to black.
          by DrankinSAW
          I bought an LG 37LG5020 with a very strange issue.. it turns on, the display looks fine, but still, after 2 seconds, the TV shuts the backlight off..
          However, if i leave it plugged in for 20-40min.. the time it takes to shutdown the backlight, doubles (to 4 seconds)..
          I bought a new inverter, set to arrive on December 13th
          11-22-2023, 01:10 PM
          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
          09-12-2024, 02:00 PM
