Dell monitor S2240L
  • pnv
    • Apr 2013
    • 11
    • Romania
    Dell monitor S2240L
    This monitor is not in standby enter the PC off after he had problems with HDMI in that we found a double entry in the video card.
    I already replaced the stop HDMI cable and displays the message that it has no HDMI cable will enter into standby in 5 min.Dupa as factory reset.
    Does anyone know where could be the problem?
    Thank you!
  • pnv
    • Apr 2013
    • 11
    • Romania
    Re: Dell monitor S2240L
    please indicate what my pin HDMI is the identification of this signal from the video card
    • Borse2008
      Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
      by Borse2008
      Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
      I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
      • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
      • There’s
      Today, 04:55 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • DanPoka
      Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
      by DanPoka
      I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
      Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
      This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
      02-15-2025, 05:05 AM
      by momaka
      03-15-2023, 10:17 PM
    • Jesus Coder
      Issues Reviving Old Dell 2408WFPb Monitor
      by Jesus Coder
      I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
      06-25-2023, 02:33 PM
