Dell monitor S2240L
  • pnv
    • Apr 2013
    • 11
    Dell monitor S2240L
    This monitor is not in standby enter the PC off after he had problems with HDMI in that we found a double entry in the video card.
    I already replaced the stop HDMI cable and displays the message that it has no HDMI cable will enter into standby in 5 min.Dupa as factory reset.
    Does anyone know where could be the problem?
    Thank you!
  • pnv
    • Apr 2013
    • 11
    Re: Dell monitor S2240L
    please indicate what my pin HDMI is the identification of this signal from the video card
    • Borse2008
      by Borse2008
      • There’s
      07-15-2025, 04:55 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
      by momaka
      03-15-2023, 10:17 PM
    • Jesus Coder
      Issues Reviving Old Dell 2408WFPb Monitor
      by Jesus Coder
      I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
      06-25-2023, 02:33 PM
