Samsung monitor 2493 HM steady blue light dead
  • SolderTrouble
    • Aug 2013
    • 24
    • U.S.
    #41
    Re: Samsung monitor 2493 HM steady blue light dead
    I read this entire thread today because my Samsung 2493HM is experiencing the same symptoms (black display, solidly lit blue LED). I got the impression that ivtec didn't understand budm's advice regarding how to test power supply board voltages when the power supply board isn't connected to the main board. Specifically: temporarily connect a resistor between the PS-ON and STBY (standby) pins of the smaller of the two connectors normally cabled to the main board, to raise the voltage on the PS-ON pin. PS-ON is an input signal that the main board uses to tell the power supply board to turn on. When the main board isn't connected to the power supply board (or if the main board is connected but isn't working right or received feedback of a problem) then it doesn't supply 2.5Vdc to the PS-ON pin, which causes the power supply to only generate 5Vdc "standby" power (needed by the main board and by the blue LED). Connecting a jumper resistor from STBY to PS-ON will supply the signal needed to turn on the rest of the power supply voltages so they may be measured.
    • valscu
      EIZO SW3031W monitor blue color instead of black
      by valscu
      I have an Eizo SX3031W monitor and after a period i had problems with the tcon board. I did reflow, it went well for a while after but the problems appeared again. The second reflow attempt was a failure, the tcon board stopped working. In the meantime, I bought a perfectly functional Samsung 305T monitor from which I took the tcon board and installed it in the Eizo monitor. Since I turned on the monitor, the blue color appeared in the background instead of black. And also in Windows, appears blue instead of black. I tried various settings from the monitor and driver settings but...
      08-10-2022, 02:08 PM
    • wattage
      by wattage
      Hello Badcaps Community,
      07-13-2025, 04:41 PM
    • ant3202
      HP 27es - LED monitor - Monitor Flashing On - Off
      by ant3202
      Hi Everyone
      Lately I am experiencing the deja-vu incident on one of the led monitor like this.
      https://www.badcaps.net/forum/troubl...lashing-on-off
      The monitor is HP 27es LED Monitor
      https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
      The monitor will randomly blackout and display no signal and will recover again.
      Sometimes need to power and off again to restore the display but...
      03-20-2025, 07:30 PM
    • Rick_1234
      by Rick_1234
      Good evening, gentlemen.
      Things I tried
      06-22-2024, 04:44 PM
      Wise Wing F199 19'' LCD monitor - recapped
      by momaka
      Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
      I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
      When I saw the Craigslist post, I wasn't...
      08-24-2020, 10:58 AM
