Shorted HP L1955
  • vbripple
    • May 2008
    Re: Shorted HP L1955
    Krankshaft... ".22 uf at 160 volts?"
    yea on the BENQ sit between the 5707 pairs. I'm assuming to stablize and absorb heat.
    only way it could be called one stop shopping is if you used just one computer to hunt everything across the net.
    • jesco_d
      • Jan 2009
      hi im new here and im also have the same problem with the hp l1955 monitor. dark screen. I'm learning a little bit of electronics and one of those transistors 5707 was shorted and a secondary fuse was open. I found a transistor in my stuff but the numbers were differant than the 5707 I just put one and the numbers was c3904. then I sodered a wire on the secondary fuse then when I powered it up the picture came up but then it would go off and on. until I started seeing smoke from the bottom of the board and then I unpluged it took the board off turned it around and the 4431 was burned. but at least I got the picture to come up. because there was no display at all before. I ordered the 4431 from newark. now I have to order at least the 4 5707 and the fuse. all the caps they look good now if anyone knows where I can get the 5707 and the fuse. the fuse I do not know what the voltage or amps. wonder if anyone can help me with this information I would appreciate it. thanks in advance. god bless.
      • Bobdee
        • Jun 2008
        • 461
        Hello jesco d
        This may help, there are more on ebay
        http://cgi.ebay.co.uk/KIT-4-PCS-2SC5...3286.m63.l1177
        can you let us know what the 4431 is, I have no board on hand, curious to find out
        thxs
        • Bobdee
          • Jun 2008
          • 461
          Its ok jesco, I think I got what 4431 is = mosfet Q805
          thxs
          • jesco_d
            • Jan 2009
            Hi there, thank you for your reply.my question is on this kit it has 2 extra transistors that I don't see on my board. one more question if you don't mind. when the mosfet 4431 blew out it kind of burn the traces underneth the chip on one side. so I am not really sure about the pin out look like on one side 3 of the pins they are together and on the other side I am not sure since the traces were burned. I just wanted to know if you know anything about it. thanks
            • Bobdee
              • Jun 2008
              • 461
              #26
              Hello jesco
              Data sheet from Krankshaft on page 2 of this thread is the 4431,it should help you, also the way it is soldered on board, some pins can be soldered together so that might help with data sheet
              the kit I posted has the c5707 and fuse, but I now know yours is a 4A fuse according to photo on page 3 of this thread, and kit has 3A, but the seller has 4A and 5A fuses in pks of 4, I mention both because on page 12 of this thread a 5A fuse is mentioned but the photo clearly shows 4A printed on it
              the other transistor FUs are not for your board but handy for many dell benqs and other monitors you may fix
              hope it helps
              • mjsbv
                • Feb 2008
                • 14
                #27
                The original fuse was a 5 Amp. The 4 A in the picture in post 3 was a temporary one I put in. I didn't want to blow the one 5A replacement I had while troubleshooting the board.
                • Bobdee
                  • Jun 2008
                  • 461
                  #28
                  Hello mjsvb
                  Thanks for clearing that 4A fuse issue for me and others,
                  I noticed in a previous post of yours, that you hit on microscopes
                  Originally posted by mjsbv
                  I did resolder the transformer pins but will look at the grey caps too. I should have taken a picture of the cracked transformer pins in the microscope but didn't think of it till it was too late.
                  May I ask if the picture of the board with 4A fuse on is taken with microscope that is connected by USB to comp ???
                  I ask because I have been thinking of buying one of these for some time,for searching cracked solder joints to save my eyes a bit, and for posting pictures of circuit/boards ect,
                  Can you recommend if this is a good way to go about this ???
                  many thanks
                  bob
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    A stereo optic microscope would be best never thought about it that way it's a pretty good idea.
                    My vision is pretty good but a microscope would make it less time consuming.
                    Originally posted by jesco_d
                    When the mosfet 4431 blew out it kind of burn the traces underneth the chip on one side. so I am not really sure about the pin out look like on one side 3 of the pins they are together and on the other side I am not sure since the traces were burned.
                    Using an unsuitable replacement (and bridging a fuse) it's just not a good idea. Wedging a FLO (fuse like object) into the fuse holder or bridging a trace to "get it working again" will FRY equipment in most circumstances.
                    The fuse blew for a reason and hopefully nothing else is broken now. You could have soldered a light bulb across the fuse and it may have prevented the magic smoke and saved the FET from overcurrent.
                    In most cases you can completely FUBAR equipment by doing this.
                    Anyhow check the traces on the other MOSFET the circuits are identical.
                    One MOSFET controls one side of the inverter.
                    • mjsbv
                      • Feb 2008
                      • 14
                      #30
                      Unfortunatly I didn't take a picture with the microscope to show the cracked solder joints and I fixed them before I thought of it. I used a stereo microscope with about a 12x zoom lense to look at it. That scope has a CCD camera that also looks through it and outputs the scene to a video monitor and a video image capture printer. A nice tool I have access to at work. I have found however that a high megapixel camera with good macro capibility can be pretty good poor mans microscope when the image is enlarged onscreen. The pictures in the earlier post were taken with a Canon powershot A620.
                      mjsbv
                      • mindless
                        • Mar 2009
                        #31
                        please explain how to open the screen?
                        Mine works OK but loud buzzing noise is heard from inside
                        • firerx
                          • Jun 2010
                          #32
                          Thank you guys for you help with the monitor caps issue. I replaced all the capacitors on the power board and my monitoris good as new. I also concur, use 105c caps on this board.
                          • orangelife2011
                            • Sep 2010
                            #33
                            dell 1800 and 1801 inverter fix have replaced 6 pin IC now flashing power light no screen
                            no Bad Capacitors. Help
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #34
                              First, this thread is the HP1955. Start a new thread for you Dell monitor.
                              Second, write in full sentences so we can understand what you are saying. This is not twitter.
                              Third, post clear focused pictures AFTER reading
                              https://www.badcaps.net/forum/showthread.php?t=1868
                              Please do not post pictures inline.
                              Take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focus pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
                              Here is an example of the pictures we want.
                              https://www.badcaps.net/forum/showpos...94&postcount=1
                              --- begin sig file ---
                              --- end sig file ---
                              • reessi
                                Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                by reessi
                                Hello:
                                I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                I started on the ACER:
                                Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                10-29-2024, 11:31 AM
                              • corrize
                                A funny fuse story – Lumix LX100 II
                                by corrize
                                Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                10-19-2023, 09:58 AM
                              • modtool
                                HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                                by modtool
                                Hi to all,
                                the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                                I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                                I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                                04-01-2025, 08:22 AM
                              • jesterace
                                Samsung UE46ES8000 Blown fuse but no other signs of short
                                by jesterace
                                Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                09-11-2024, 03:14 PM
                              • barry101
                                Apple 820-3662 VCore shorted to ground.
                                by barry101
                                Hi, Would appreciate some help.
                                I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                                Get charger light but no fan spin or chime. No liquid damage.
                                Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                                Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                                With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                                Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                                06-24-2025, 07:34 AM
