BN44-00195A strikes back!
    replied
    Re: BN44-00195A strikes back!
    So we can still cannot get the PFC IC to run some how.
  • steven10
    replied
    I'm getting steady19V VCC (pin 8) and 0.00V on pin 7(pin out)
    replied
    Originally posted by steven10
    I'm getting ~350V on the big cap both with power on and off
    That is not right, the PFC Voltage should be activated when the PS-ON (ON/OFF) signal is received from the main/logic board. I do not think the PFC is running.
    So are you getting the DCV between the VCC pin and GND of the PFC IC controller?
  • steven10
    replied
    replied
    At least you have 20V or so feeding the inverter board, then the inverter board should try to light the lamp when the inverter board gets the BL-ON commnad signal.
    BTW, what is the PFC boosted Voltage do you get now?
  • steven10
    replied
    Shipping time takes to long, so I ended up going to a "local" store, 2 days and the parts were there
    Parts replaced and still black screen but i'm now getting 20.5/22.7V(fluctuating) on the 24V line(before was 0.00V ).
    Any suggestion?
    PS: Reading taken with everything plugged in
  • steven10
    replied
    Ok,tested the MOSFET with a 9 volt battery and it is good(probably my DMM doesn't have enought power to turn this MOSFET ON).
    Put it back and read 0.67V on pin 7(PFC output pin).
    Checking for low resistance readings on the IC, I got :
    1)6K7
    2)5K8
    3)1M1
    4)1R
    5)5K8
    6)GND
    7)5K5
    8)170R
    Pins 1,3,4 and 6 seems good.
    Pins 2,5,7 seems bad.
    By removing the jumper that drives the VCC to the SMPS IC, I'm able to read correct 7K4 on pin 8 of the PFC iC, so pin 8 is good,but the SMPS IC is bad
    I ordered a FAN7530M and a MC33067N,any chance changing these parts can return the monitor in a working condition?
    replied
    You can try another power MOSFET with the same rating.
    Not much you can do for testing the IC, You can test the resistance readings between GND pin against all other pins to see if they show low resistance.
  • steven10
    replied
    How can i test di PFC IC?
    Can i put a working 600V 7A mosfet just to check if I'll get the boosted voltage?
    replied
    So now you do have 16V for PFC IC VCC but still no boosted Voltage, so it can be bad IC or Bad MOSFET, but 99% the bad MOSFEt will fail in shorted out mode.
  • steven10
    replied
    I've pulled off QP801s and it seems bad.
    The source-drain diode is fine but I'm not able to turn it on the "On state"...
    When I charge the gate capacitance, I got no readings between drain and source(open circuit).
    Before pulling off QP801s I was getting 15.9V on the Vcc line, so the PFC IC was getting what it needs to run.
    The 19.5V on the QB802 collector seems to be low and I don't know why the voltage getting higher when power is off.
    maybe something related to the bad QP801s mosfet?
  • steven10
    replied
    I replaced QB802 with a 2sd2394 60V 3A NPN transistor.
    didn't found a 15V zener ,but I just replaced it with a 10v zener in series with a 5.1V one.
    These were the reading BEFORE changing those parts:
    Power ON/OFF:
    A = 17.9V/15.7V
    B = 11.7V/9.7V
    These are the reading AFTER changing the parts:
    Power ON/OFF
    A = 19.5V/22.5V
    B = 15.9V/0.0V
    The voltage between the big cap almost remained the same,now it fluctuates from 310V to 325V(305V to 310V before) both with power ON and OFF
    Still 0.01V on the 24V line.
  • steven10
    replied
    Originally posted by budm
    Great so you need to get the 15V ZENER and the NPN TO-220 60V 2~3A rating.
    Do you have any scrapped board for steling the parts from?
    I found a 2sd2394 (TO-220F package)NPN 60V 3A transistor from a scrapped power supply board,it should be fine.
    Tommorrow I'll check for zener,it's over midnight here
    replied
    The diagram is not exact match with the *-00195 board.
  • steven10
    replied
    Of course I mean QB801(QB802 on the diagram) not QM801... my mistake
    replied
  • steven10
    replied
    QM801 is bad!
    I just removed it from the board and it has a short between B and E...
  • steven10
    replied
    These are the readings:
    17.9V between A and GND REF
    11.7V between B and GND REF
    While looking very close to the smd side of the board(thanks to your picture),i've noticed that DZB805 had a tiny little crack on top of the package,just a gentle touch with a sharp screwdriver caused the package to break.
    Now there's a "huge" hole on this,i'm going to test it but i think it's 99% bad.
    I also noticed that QM801 shows a very low resistance between Emitter and Base, don't know if this depends on the bad zener...
    replied
    OK, I found my old notes.
    QB801 is for the 15V regulator circuit.
    Check the DCV between A and GND REF, B and GND REF when power switch is activated.
    replied
    I expect the VCC to be around 15~18V range when it is running, 11.8 is pretty close to then minimum 11V, worst case is 12V requirement for start up.
    If you look at the diagram of the BN44-00192, you will see the 15V linear regulator transistor QB802.
  • TinkerTron
    Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
    by TinkerTron
    Hey everyone,
    I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
    Instead, here's what's been bugging me so far:
    The schematic...
    03-06-2025, 02:03 PM
  • brightest_z
    Hot Air Blew Away Resistors Near Bios
    by brightest_z
    Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
    Does anyone with more knowledge, and experience than I, know if this is the case?
    12-11-2024, 08:34 PM
  • jinu_j
    LED driver circuit. Burnt Resistors
    by jinu_j
    Hi Folks
    This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
    Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
    But i have some queries on this circuit
    1. The resistors that burnt to crisp...
    08-26-2020, 01:24 AM
  • repair-it
    Pioneer VSX-40 ,Trying to ID these resistors
    by repair-it
    I am trying to determine why these two resistors are the colors that they are. This is a Pioneer amp. The ones I am concerned about are the RED & GREEN colored resistors. I need to replace them and want to be sure to use the properly rated component....
    12-16-2024, 02:08 PM
  • BustinCaps
    Dell 2007WFP resistors under white silicon blog
    by BustinCaps
    My beloved 2007WFP just died on me. It has a green blinking light that just cycles through various display numbers. For a while I noticed it would blink slightly like the refresh rate was off. Nothing I have done has been successful in turning it on. So I took it apart and looked at the USB board since many people have had problems with the resistors under the silicon blob. I looked at the various other boards for the obvious signs such as blown caps, bad fuses, burn marks etc. Nothing looked obvious. I also checked most of the caps with an ESR meter and they checked out good.
    04-29-2022, 06:19 PM
