Have this power problem. Monitor would just not come back on. No power LED at all. After letting sit for a couple of months with no power disconnected and no monitor cable connected, the monitor would power up with no problem. All the LCD CCFL's are good, but after a few days the power goes off and again no power led light. I have completely disassembled the monitor and checked the power board. Reconnected the control board, tcon board and the power board. Powered up nicely, but after running for a couple of days, turned off the monitor using the power button, came back to work from over the weekend and now will not power up. I am very familiar with the 2 seconds to black issue, but this does not sound like it.
Dell E2010Hc power problem
Assuming...7 Photos -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by penangitHey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
Steps taken so far:
Checked all...-
02-21-2023, 04:00 AM -
- Loading...
