Hp lp3065
  • Sgoaty
    • Aug 2015
    • Scotland
    Hp lp3065
    Hi
    Yesterday MY HP LP3065 developed a fault. It will only stay on for around 10 seconds then the screen will go blank for around 10 seconds. The green light changes to orange for around a second then goes back to green and the screen powers back on for another 10 seconds. It will stay only slightly longer when first powered on but still under a minute.
    I have tried connecting it to a different source and using a different DVI port but the fault stays. The panel is faultless so it seems a shame to bin the screen if the issue can be fixed. I don't know much about electronics but Ive got nothing to lose (well I suppose I could get electrocuted).
    Can anyone offer advice on this please?
    Scott
  • TVRepairNoobie
    • Feb 2015
    • 158
    Re: Hp lp3065
    Open the back of the case and post some clear pictures of the boards.
    • Sgoaty
      • Aug 2015
      • Scotland
      Re: Hp lp3065
      It came apart pretty easily probably because half the screws were missing. Its also full of duct tape and has a glued in multiplug.
      I got it cheap a couple of years ago so Ive definitely had my moneys worth and after seeing the bodging that's gone on inside I'm not sure if its worth trying to fix really.
      • ravi_1617
        VBU30 LA-9223P ,stay on for 5 seconds,
        by ravi_1617
        Hi to all.
        This HP board LA-9223P stays on for not more than 5 seconds,
        Problem no V-core power .
        PL302 3.3+3VALWP OK
        PL303 5+5VALWP OK
        PL402 1.5 VP OK
        PL602 1.8 VSP OK
        PL5021.08 VCCP OK
        PL1002+1.5V_PCIEP goes to 1.2-8 Mil volt
        PL204 .7 Mil VOLT+VGFX_CORE
        PL202 2.2 mIL Volt +CPU_CORE
        Please Help
        https://www.badcaps.net/forum/troubl...eed-schematic-...
        02-05-2025, 09:36 AM
      • twonk9098
        Lenovo Legion 5 high fan spin turns off after 34 seconds
        by twonk9098
        I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
        I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
        I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
        I have tried a few new bios but exactly...
        07-14-2024, 11:19 AM
      • liquidzorch
        Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
        by liquidzorch
        Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
        10-18-2024, 05:19 PM
      • Rick_1234
        by Rick_1234
        Good evening, gentlemen.
        Things I tried
        06-22-2024, 04:44 PM
      • PowellSkier
        Harman/Kardon AVR 645 returning to stand-by after a few seconds.
        by PowellSkier
        A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
        06-17-2024, 11:43 AM
