Hanns G HG281D 28" Monitor Video Problem Any Ideas??
  • WitSlitWrist
    • Jul 2015
    • 3
    Hello I have a Hanns G HG281D monitor that stopped working for me , the monitor show a great picture when it comes on , but after 2 or 3 second the video cut off, and the power light stays on with no video display.
    After doing some research I found that many people were having the same problem and advised me to change the caps. I ordered a Kit and replaced all of the caps on the power supply board but I'm Still having the same problem. Does anyone has any ideas on were to start looking next?
    Re: Hanns G HG281D 28" Monitor Video Problem Any Ideas??
    Did you replace at least the two caps for the Voltage regulators on the main board?
    Just do the search on BC for HG281.
    https://www.badcaps.net/forum/search...archid=4969679
    • WitSlitWrist
      • Jul 2015
      • 3
      Hmmmm no but I'll check and let ya know so far all caps replaced were on the power supply , thankxx for the reply
        https://www.badcaps.net/forum/showth...281#post571641
        • thukud
          • Apr 2018
          • 9
          • kenya
          I have the same problem of the same kind of monitor. Did you you get the solution?
          • ayhan yılmaz
            • Mar 2018
            • 40
            • TÜRKİYE
            Hi Man Problems with lamps & invertör transformer problems https://www.merterelektronik.com/LCD...LA_2620-2.html lamp and inverter transformer Remove. this lamp and card ok.https://m.tr.aliexpress.com/item/326...to-LED-Monitor
            • thukud
              • Apr 2018
              • 9
              • kenya
              I read somewhere that if you decrease brightness the problem will be solved.
              but think what, brightness is stuck at maxmum (100) and contrast at 70. Whenever I try to reduce them they go 2 or 3 steps down then they jump back to original values. any ideas on what I can do
              • R_J
                • 9558
                Try replacing those caps for the regulator ic's on the logic board.
                • thukud
                  • Apr 2018
                  • 9
                  • kenya
                  only those two or enrire caps. I ask that because when I connect vga cable it takes shorter time for display to disappear than when I use hdmi cable. Also I would like to know which part has failed that make the monitor not to operate for long at maximum brightness. i will appreciate
                    I would replace just those two caps first.
                    If it is my monitor I would replace the power supply caps (there are listing some where on B.C. for the caps used in the power supply) and those two caps on the main board.
                    • thukud
                      • Apr 2018
                      • 9
                      • kenya
                      I have checked the power supply and they look healthy. And to be currious what purpose do those two serve. I was thinking of replacing the inverter board caps. Is it a good idea? Is there certain brand which work best?
                        Bad cap can look normal, you need to actually check the capacitance and ESR.
                        Those two caps on the main board are filter cap for the LDO regulator IC's and they will look just fine too.
                        • thukud
                          • Apr 2018
                          • 9
                          • kenya
                          I first changed those two caps on logic board and alas,I was able to adjust brightness and contrast. Then I changed four caps on power supply board two rated 1000microfarads/35volts and two rated 680microfarads/25volts. So far so good it worked. Thanks R J and budm for your support. God bless
                          • thukud
                            • Apr 2018
                            • 9
                            • kenya
                            Partial lockdown caused my hanns g monitor to stay idle for 3 months. When I powered it I realize that the screen has divided itself in 3 parts horizontally. Bottom part is black, middle part is white and top part you can see image. What could be the cause?
                            • thukud
                              • Apr 2018
                              • 9
                              • kenya
                                by momaka
                                03-15-2023, 10:17 PM
                                HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                09-12-2024, 02:00 PM
                              • wattage
                                AOC AG493UCX 49-inch monitor - Firmware request
                                by wattage
                                Hello Badcaps Community,
                                The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                07-13-2025, 04:41 PM
                                Wise Wing F199 19'' LCD monitor - recapped
                                by momaka
                                Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                When I saw the Craigslist post, I wasn't...
                                08-24-2020, 10:58 AM
                              • sew333
                                Pc shutdown, monitor flickered with no signal after 10 seconds
                                by sew333
                                My pc:
                                10850K stock 4800mhz stock Kraken X73 good temps
                                2x16 GB DDR4 GSKILL 3000mhz XMP
                                Seasonic Tx-850 Ultra Titanium
                                Gigabyte Rtx 3090 Gaming OC
                                Aorus Z490 Pro Gaming
                                1 TB SSD
                                4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                Power...
                                02-22-2022, 10:27 AM
