Dell 2007WFPb 2 seconds to black
  • qu1j0t3
    • Jul 2011
    • 14
    Have replaced inverter board caps with no change.
    I checked the "272" SMD resistor on the usb board (the one covered by goo) as others have done (I first saw it in this thread https://www.badcaps.net/forum/showpo...4&postcount=10), and it reads a nominal 2.8K. However the SMD component next to it reads open—not sure if that's an issue.
    I also measured transformers as described in this post:
    https://www.badcaps.net/forum/showpo...6&postcount=14
    All readings are nominal ~ 1.06 but one is ~1.25. Is that an issue?
    I have not measured voltages, can someone point me to the best place to do that?
    Board P/N 5EL2J02001 - I can post pics tomorrow if that is helpful.
  • qu1j0t3
    • Jul 2011
    • 14
    Re: Dell 2007WFPb 2 seconds to black
    I quoted the logic board part number. The inverter board model is 4H.L2J02.A05.
    • HTR-Informatique
      by HTR-Informatique
      02-09-2025, 06:51 AM
    • ChIck3n
      Dell u2311h 20000 seconds to black issue
      by ChIck3n
      So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
      09-09-2024, 11:44 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • jake-b
      dell e6540 boots to black screen (no dell logo)
      by jake-b
      good morning all,
      i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
      01-08-2024, 10:29 AM
    • Swedishpower
      Dell G3 15 3500 black screen
      by Swedishpower
      Hello
      I have search everywhere for a solution for my problem, but cant find it anywhere.
      When I was away to trow some garbage i always look in the electronic bin.
      and this time i find a laptop.
      Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
      the lamp for charmig is white.
      Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
      but no Dell logo.
      I tryed with a hdmi cable to another screen, still black.
      I started to search solution and tryed...
      07-06-2025, 06:18 AM
