Samsung 204BW LCD monitor
  • Capsized
    • Mar 2015
    • 9
    This monitor recently went dark. Found three swollen capXon capacitors and replaced them. Unfortunately during the process I broke what Samsung calls the FUNCTION PCB on the front bezel. That was because of not noticing that while trying to figure out how to get the monitor apart I inadvertently put too much strain on the PCB harness (4 tiny wires). The board cracked just past the second button from the left.
    Don't think that I can repair this board. The traces are incredibly tiny and closely spaced.
    My preference would be to buy a replacement FUNCTION PCB. It has what looks to be a part number stamped on it. Can't find it by Googling so far.
    Next best option would be to buy a replacement bezel which seems to include the FUNCTION PCB from what I can tell. Haven't had much luck in locating one of these yet either.
    Your suggestions would be most welcome.
  • thunder77
    • Mar 2012
    • 27
    • Romania
    Re: Samsung 204BW LCD monitor
    Capsized, first post a clear picture of the PSU. Or give us the P/N.
    Also check this link. I think this is your power board... http://www.aliexpress.com/item/LCD-M...648820594.html
    • Capsized
      • Mar 2015
      • 9
      The part number for the Function PCB is: ASJ0642E
      After the capacitor replacement I tried to use the monitor without the Function PCB but got nothing. Perhaps the Function PCB must send an input to the main board to make the monitor turn on? Or perhaps there is another problem other than the capacitors.
      That power board picture you provided does look like mine.
      Bought another bezel on eBay for a similar monitor with its own Function PCB. Not the same part number, but it has the same labels on the push buttons and only four wires, but it has a 6-pin connector, of which two pins are not being used. Whereas my connector is 4-pin. My plans are to splice the new Function PCB wires to my PCB's connector and try it out.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4367
        • Italy - Milan
        Can you post a picture of the phisically broken pcb?
        • Capsized
          • Mar 2015
          • 9
          I'll have to wait until the wife comes home with her smart phone.
          • Capsized
            • Mar 2015
            • 9
            Here are a couple of pics.
            Found that the harness for the PCB could be disconnected. Unplugged the old harness and plugged it into the "new" PCB. No need for cutting and splicing wires after all.
            Still no success, however. Monitor still black. But now the blue LED on the Function PCB lights again. It was illuminating before I broke the PCB.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4367
              • Italy - Milan
              I see nothing from the pictures, practically i wanted to say if there is the possibility to solder wires between the button pins and the connector pins, rebuilding all connections..
              • selldoor
                Slow Learner
                • 7870
                We are lost without good pictures of the function board and both sides of the boards in your monitor
                • Capsized
                  • Mar 2015
                  • 9
                  Thought I had attached those pictures, but evidently something went awry.
                    09-07-2024, 05:50 AM
                    by momaka
                    03-15-2023, 10:17 PM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
