Viewsonic Vp201B flickering
  • beanbag
    • Mar 2015
    • US
    Hello folks,
    I have an old Viewsonic VP201b that has worked for many years, and finally started to flicker for several seconds upon first turning it on in the morning. By flicker, I mean the display quickly pulses on and off for a few seconds, and finally becomes stable.
    I took the monitor apart and first suspected the power supply, because I was measuring the voltage during the flickering, and the power supply would quickly dip down below it's nominal voltage. But then I took the power supply out and replaced it with an external supply, and that did the same thing, namely the voltage would drop quickly while the display was flickering. So I don't think there is anything wrong with the original PS, but rather, it seems like something else is rapidly and intermittently shorting, causing the supply voltage to dip.
    I don't see any bulging caps or other burn marks anywhere on the boards. Any suggestions where to look or diagnose?
  • 1supertech
    • Apr 2012
    • 384
    Re: Viewsonic Vp201B flickering
    Lower backlight intensity does it still flicker check capacitors on mainboard
      • 30962
      does it have hours used in the system menu anywhere?
      • beanbag
        • Mar 2015
        • US
        Thanks for the suggestions. The monitor is apart right now, so I can check in a few days.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
          07-01-2024, 06:34 AM
        • Fagauthier
          Viewsonic power supply model #EADP-64BF B Need circuit diagram…
          by Fagauthier
          I have à defective Viewsonic monitor. I can't find a circuit diagram for it' power supply.
          Model #EADP-64BF B
          The user manual have all diagram except for the power supply. I would appreciate help to find the circuit diagram, thanks...
          07-08-2023, 08:02 PM
        • CMCM
          Russound CA4 Power Supply Repair
          by CMCM
          Hello Everybody,
          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
          The outputs marked 12v and 20v are all measuring only 1v.
          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
          The capacitors physically look clean (no bludgesor leaks) and...
          07-03-2025, 01:12 PM
