Viewsonic LCD monitor bad. Need help identifying bad part.
  • dss
    • Jan 2015
    • 5
    I have a Viewsonic monitor VX2739wm that is getting a picture but going to a blank black screen after a second.
    I opened it up and all the capacitors look fine but a part labeled T2 looks like it is burnt out.
    See images of the bad part.
    http://imgur.com/3PLp0k5
    http://imgur.com/cdmbGl5
    There are some additional pictures of the board and manufacturer, model number etc but it seems like no one has the board in stock.
    Would anyone know how I can get a replacement for the T2 part that looks like it has burnt out?
    Thanks in advance! Sincerely, David
    Pictures of entire board
    http://******/1ChzcyL
    http://www.shopjimmy.com/viewsonic-f...t-inverter.htm
    Part Type Backlight Inverter Board Power Supply Unit
    Part Number FSP068-2L01
    Board Number(s) 3BS0238813GP
    Known Models VIEWSONIC VX2739W
    Panel Sticker Number M270H1-L01 Rev.C1
    Panel Manufacturer Chi Mei
    Re: Viewsonic LCD monitor bad. Need help identifying bad part.
    That is the Inverter transformer with burnt out high voltage winding.
    http://www.ebay.com/sch/sis.html?_nk...+Samsung+710MP
    It can burn out if you have bad lamps, you should also check the components that drive the transformer to make sure they are not damaged.
    • dss
      • Jan 2015
      • 5
      Budm,
      Thank you for your quick response.
      I am really a serious newbie. When you say "you should also check the components that drive the transformer to make sure they are not damaged."
      Are you saying that I should visually inspect them or something more involved than that?
      Thanks again for your help with all of this!!!
      Sincerely,
      David
        You will have to test the SMD components on the bottom side of the board, especially the MOSFETs that drive the transformers to see if they are shorted out or not. If they are bad then you will need the tools to do surface mounted repairs.
        Checking the lamps will be a lot more difficult due to you have to take the LCD panel apart down the lamp assembly.
        Transformers are not cheap so you can take a chance and spend $42 on the board and hope that the lamps are OK.
        • dss
          • Jan 2015
          • 5
          THANKS Budm!!!
          • dss
            • Jan 2015
            • 5
            Budm,
            I have been unable to find the transformer anywhere SP1 8TC00541. Is there an alternative transformer that I can use instead of this one?
            Thanks,
            David Springer
            • artvandalai
              Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
              by artvandalai
              This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
              The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
              11-05-2024, 07:38 AM
            • VoicE2000
              usb-c hp elite x2 help me identifying this part
              by VoicE2000
              Hello all, Can anybody help me identifying this part its on the usb c line on a hp elite x2 ,Seem like a filter or cap ,or some sort of short or polarity protection.anyway its blown.
              07-15-2024, 10:51 AM
            • wattage
              AOC AG493UCX 49-inch monitor - Firmware request
              by wattage
              Hello Badcaps Community,
              The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
              07-13-2025, 04:41 PM
            • edugimeno
              Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
              by edugimeno
              Hi There!
              I'm trying to help my friend who owns a restaurant be just bought.
              He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
              It's stuck using, I guess, the 2 sided tape that comes with the strip
              The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
              09-05-2024, 09:34 AM
            • G-Sting
              iPad Pro A1876 SHORT Part Identify Help Needed
              by G-Sting
              So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
              So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
              i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
              SO My main concern is what part should i order what should i search the name for ?
              on Ipad...
              05-15-2025, 09:30 AM
