Is This Typical GPU Failure ?
  • mmartell
    • Oct 2013
    • 3189
    Re: Is This Typical GPU Failure ?
    Spoke too soon. After a reboot very few artifacts but the cpu/gpu fan running quite a bit faster. Ah hell will try reflow one more time
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      #42
      Remember to reapply good quality thermal compound. And don't be afraid to blast the die with really hot air - just don't do the same for the green substrate.
      A working TV? How boring!
      • mmartell
        • Oct 2013
        • 3189
        Ya I hit it at 450f but I only ever use the station at 500f as it is mostly useless below it but I figured after four minutes it would work. I've got no problems hitting it again at 500
        I will say I only have generic paste but have never had a problem with it the several times I've used it, lastly on an LG z-sustain. How hot does the vram get ? I've been reusing whatever goop is on there already as I have no thermal pads let alone know what thickness to use.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          #44
          The VRAM does not get hot, there's no problem leaving the old pads on.
          Oh, so you were talking deg F. I was talking Celsius. Does it even melt solder at 450F? You will want to use a setting that you would normally use for desoldering small parts.
          • mmartell
            • Oct 2013
            • 3189
            If you're NOT talking F you're going to burn your house down. Or I could be confused, wouldn't be the first time
            • mmartell
              • Oct 2013
              • 3189
              And btw, I'm guessing there's no solder inside the die so how does heat repair the connections even temporarily ?
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                #47
                I am talking Celsius. Really. Remember the hot air station will have its sensor inside, in front of the heater element. By the time the air goes thru the nozzle and into the outside world, it cools down significantly.
                If you use a multimeter probe put in front of the nozzle of your hot air gun, it should read around 320C. I can't see how lead-free solder would melt any lower than that anyway. I use 400C for working with leaded solder and 430-450 for lead-free. I don't think my station is poorly calibrated as this is my 2nd one and i'm using the exact same settings. My hot air station is a ZD-939B.
                I have however found that for Gordak ones you need to set the temp lower, as the heater seems to be higher power. The Gordak i had at work did not have its heater marked in deg C, just from 1 to 8. I had to use it at the "5" position or slightly lower on sensitive boards otherwise it would burn them.
                There is solder inside the die, obviously. How do you think they connect them otherwise? They don't use bond wires anymore for chips this dense.
                • reaper57
                  • Sep 2014
                  • 216
                  • Norway
                  #48
                  The problem might not be the bga under the chip. The crystal is also connected to the die via solder balls. They are a lot smaller, but still solder.
                  Also you can take a look at this, it should clarify why heat effects it.
                  https://books.google.no/books?id=G9A...%20die&f=false
                  Also if you had your station set at 450F the first time, that would explain why there still are artifacts. The air gets a lot cooler by the time it gets to the chip, and if the problem is the solder under the chip it's even cooler when it reaches it. I wouldn't be surprised if the chip was at under 150C (302F) during the reflow. But this is good! If the chip starts to show signs of life with only a low temp reflow, that means that there is a good chance for it to be fixed by a proper one.
                  Keyboard not detected, press F1 to continue...
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    #49
                    That is exactly what i was talking about. These nvidia chips are known to have a problem there.
                    • mmartell
                      • Oct 2013
                      • 3189
                      A quick update: all artifacts have disappeared and the display is rock solid. This is without another reflow and also without stress testing. Temperatures as reported by the sensor seem nominal at about 35c. The cpu/gpu fan runs quite a bit faster than it did when the computer was "broke" so I'm still going to disassemble it to make sure I didn't leave a sensor unplugged and also check the heatsink-gpu surfaces.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        #51
                        If it ain't broken, then don't fix it. These things do fix themselves sometimes. If it breaks again, hit it harder next time.
                        • Themi
                          Dell XPS 13 9310 2 amber 4 white memory failure
                          by Themi
                          I have this laptop a dell XPS 13 9310
                          Power on is ok, stuck at dell logo flashing 2 amber and 4 white (link dell service manual) 2,4 Memory or RAM (Random-Access Memory) failure​
                          I believe this is the spec from using micron tool to decode marking
                          Images of the ram
                          I am thinking to replace but wondering if there is a possibility to test while in circuit to find the faulty module? I am doubting there is any reasonable test possible while in circuit as most ram ICs I have tested previously, I have done while off board / removed.
                          Another...
                          11-24-2024, 09:06 AM
                          MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                          This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-06-2024, 07:46 AM
                          MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                          This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                          09-06-2024, 07:29 AM
                          MSI Prestige P65 8RF Creator White Notebook P Specification for Upgrade or Repair
                          This specification for the MSI Prestige P65 8RF Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF Creator White boardview and P65 8RF Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-06-2024, 07:25 AM
                          MSI Prestige P65 8RF-445ES Creator White Notebook P Specification for Upgrade or Repair
                          This specification for the MSI Prestige P65 8RF-445ES Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-445ES Creator White boardview and P65 8RF-445ES Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
