KDS XFlat 19" CRT out of focus
+ More Options
Posts
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    I've got a CRT here at work that suddenly went out of focus this morning. Any thoughts on causes, and if it can be fixed? IF it were a 15 or a 17, I wouldn't bother, but the 19 might be worth it if it's an easy fix.
    Ludicrous gibs!
  • Spacedye69
    • Nov 2005
    • 698
    • US
    Re: KDS XFlat 19" CRT out of focus
    If it suddenly went out of focus as opposed to a long, slow dimming/ fuzziness, its probably low voltage on the 140v. Check the caps is the ps section for a 160v-200v around 100uf to 300uf.
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      brightness is still fine... it just suddenly went fuzzy.;
      Ludicrous gibs!
      • Maxxarcade
        • Jul 2006
        • 973
        I have a 17" KDS that did the same thing. It has a very touchy focus knob on the flyback. Maybe that is the problem you have as well. Check solder joints and caps while you're in there too.
        • Krankshaft
          • Jan 2007
          • 2328
          The reason your focus went fuzzy is because the focus voltage supplied through the flyback dropped.
          If the brightness is still fine try turning the focus POT on the back of the flyback with the monitor running. If that fixes it close it up and let it run and see if it slips back out of focus again.
          It could be that one of the resistors inside the flyback voltage divider bit the dust causing the voltage to go off.
          It couldn't be the supply voltage if it was the brightness would have dropped too.
          • linuxguru
            • Apr 2005
            • 1564
            There's probably a bad joint or bad cap somewhere in the flyback section - start by reflowing all beads that look dry or suspect. Then think about replacing caps.
              HP ProBook 450 G9 + Voyager Focus 2 UC Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 450 G9 + Voyager Focus 2 UC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G9 + Voyager Focus 2 UC boardview and 450 G9 + Voyager Focus 2 UC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
              09-07-2024, 07:12 AM
              HP EliteBook 650 G9 + Voyager Focus 2 UC Notebook Specification for Upgrade or Repair
              This specification for the HP EliteBook 650 G9 + Voyager Focus 2 UC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G9 + Voyager Focus 2 UC boardview and 650 G9 + Voyager Focus 2 UC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
            • vom513
              Tatung VM9AF 9 in. VGA Monochrome - focus lost after recap
              by vom513
              I just recapped one of these (Tatung VM9AF). Now the image is badly out of focus. Mainly on the horizontal.
              Rear focus pot. doesn't help in any meaningful way.
              Anything else I can look at ?...
              01-11-2024, 08:16 PM
            • randomrat
              Alienware X15 R2 LA-L611 No power
              by randomrat
              ​Not having the best of luck with my own gadgets atm - I own two identical X15 R2 laptops, both have died suddenly with no prior issues. I have time to focus on one of them and in this post. I might need some hand-holding with this so I kindly ask for some understanding
              Make: Alienware
              Model: X15 R2
              Motherboard: LA-L611
              CPU: i9-12900H
              GPU: RTX 3080Ti
              History: I was using the machine as normal when it suddenly switched off and never came back on. I've owned the machine for over a year and use a Dell Thunderbolt Dock to charge my laptop with....
              03-29-2025, 12:18 PM
            • PowerAmpFreak
              CD player focus and tracking adjustment
              by PowerAmpFreak
              Hi all I have a Krell KPS-28c hi-end CD-player which I replaced the laser since the old one had very low RF output.
              Now the RF level (eye pattern) is about 1.8V peak to peak.
              The problem is it skips like 5-10 times per CD.
              I have been looking into focus and tracking errors and try to diagnose.
              The CD-drive is a TEAC VRDS-7.
              On the focus error testpoints there are some jumps in the waveform while I see not such issues on the tracking error testpoints.
              Anyone know the procedure of an adjustment of this drive?...
              07-14-2022, 07:18 AM
