Dell 2408WFPb: multicolour vertical stripes
  • HAHOMETP
    • Nov 2012
    • 155
    Folks,
    I have a Dell 2408WFPb with a defective T-Con board (determined by swapping parts with the known good 2408WFPb). I touched up each and every soldered pad on this board with my Weller pencil, but the problem is still here. I also tested the fuse F1 as well as all of the 0 ohm resistors and every p-n junction on the board except for the 5 chips. Which part might be causing this condition?
    Please see the attached pix of my good 2408WFPb with the T-Con board lifted off the bad 2408WFPb.
    Re: Dell 2408WFPb: multicolour vertical stripes
    Did you check the Voltages on all 3-pin Voltage regulators? There are 4 (U7, 9, 19, 21) of them, and since you do have working board then you can do the comparison readings.
    • HAHOMETP
      • Nov 2012
      • 155
      All four voltage regulators are LD1117 by ST Microelectronics. According to the datasheet they come in several output voltages (1.2V, 1.8V, 2.5V, 2.85V, 3.0V, 3.3V and 5.0V).
      Here are their actual output voltages as measured on Pin2:
      IC7 (marked LD1117): 2.51v
      IC9 (marked LD1117): 2.52v
      IC19 (marked LD18): 1.81v
      IC21 (marked LD33): 3.31v
        IC7 and IC9 are adjustable 1117. Can you please verify the Voltage between pin 1 (ADJ) and pin 2 (output), it should be 1.25V.
        IC19 (1.8V REG), 21 (3.3V reg) are fixed outputs.
        • HAHOMETP
          • Nov 2012
          • 155
          budm,
          you're right as always. I overlooked that they were adjustable. I am wondering why Dell did not use the 2.5v fixed ones instead. Anyway, they both check out.
          IC7: 1.269v on Pin1
          IC9: 1.274v on Pin1
          • HAHOMETP
            • Nov 2012
            • 155
            Also, the previous owner stated "Monitor turns on and displays an image but has the blocks on the screen that overlay (see image). The blocks used to go away once the monitor was warmed up but now they are there all the time. "
            Attached are the pictures that were provided by him. If he is telling the truth the problem has progressed from the intermittent boxes on the cold monitor to the permanent stripes that I am seeing. I left the monitor on overnight but the stripes did not go away.
            • justanothercanuck
              • 8
              I once had a Dell laptop that displayed this issue (or something similar), it turns out it was a panel fault. If I recall correctly, the individual lines on the vertical would just choke and get stuck on a single colour, or flicker between a handful of colours. Happened to a whole bunch of them about 10 years ago. Was covered under a grandfathered warranty, but the laptop was too old for me to care at that point.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4954
                • New Zealand
                Did those 2 big chips on the board have heatsinks? Because it looks like they did but no longer do...
                -David VanHorn
                • HAHOMETP
                  • Nov 2012
                  • 155
                  The whole T-Con board is covered with a thin steel shield. There are two square pieces of rubber like material about 3mm thick on its inner surface. They get tightly pressed up against the two large chips when the shield cover is secured to the board with 4 screws on the perimeter. Quite possibly these two pieces are indeed some heat sinks of sorts. I need to figure out how to spray the T-Con board with compressed air to freeze it and see if the stripes disappear. For that I need to relocate the power supply board mounted above the T-Con board.
                  • HAHOMETP
                    • Nov 2012
                    • 155
                    In my case the T-Con board is most definitely at fault. I swapped the T-Cons between the two identical 2408WFPb Dells and the problem migrated from one monitor to another.
                    • HAHOMETP
                      • Nov 2012
                      • 155
                      The T-Con boards for Dells 2408WFPb (LTM240CS05FFCC4LV0.4) and 2407WFPb (LTM240M2C4LV2.4) are almost identical and the connectors are the same and are located in the same places.
                      Does anyone know if are interchangeable?
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4954
                        • New Zealand
                        No idea. Compare schematics?
                        -David VanHorn
                        • HAHOMETP
                          • Nov 2012
                          • 155
                          I wish I had them...
                          • dragos2009
                            • Mar 2013
                            • 110
                            • Romania
                            the first one has a connector on left and the other one doesn't have that connector and even the main chip and panel connector are different
                            • HAHOMETP
                              • Nov 2012
                              • 155
                              Good catch RE: connector on left. I missed it. Thanks!
                              • HAHOMETP
                                • Nov 2012
                                • 155
                                An update. A used T-Con board off ebay (20 bux delivered) has fixed the issue.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4954
                                  • New Zealand
                                  Nice!
                                  -David VanHorn
                                  • Achim64Germany
                                    • Feb 2015
                                    • 30
                                    Hello Friends,iam from Germany and my english is not so good sorry.Iam new here and iam a hobbyist Tech.
                                    Please i need help for my Dell 2408.First there is a Diode wrong (broken) on the Powerboard.What Diode i need for repair?
                                    Thank you Achim
                                      Please upload good clear pictures of YOUR boards and point out which Diode is broken.
                                      http://s807.photobucket.com/user/bud...?sort=3&page=1
                                      • Achim64Germany
                                        • Feb 2015
                                        • 30
                                        http://img4.fotos-hochladen.net/thum...rxyo_thumb.jpg
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • kotel studios
                                          Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                                          by kotel studios
                                          Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                                          In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                                          08-06-2025, 02:07 AM
                                        • halen
                                          Hisense H55U7B vertical stripes
                                          by halen
                                          I have Hisense H55U7B TV with no picture, only big vertical stripes. I did several tests and I'm not sure, where is problem.
                                          1. Connected tcon to 12V, white, red, green, blue, black picture visible in cycle on full LCD without error
                                          2. Connected only left side of LCD to tcon, big stripes
                                          3. Connected only right side of tcon, visible normal picture on the right. Working as expected.
                                          Where could be problem?
                                          Tcon RSAG7.820.7932/ROH
                                          Main board RSAG7.820.8698/ROH
                                          Jan
                                          06-18-2025, 03:58 AM
                                        • ahoonid
                                          MacBook A1990 vertical stripes on external screen
                                          by ahoonid
                                          Hey everyone,
                                          I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
                                          The board is neat. Not opened before for sure. Just a little dust, nothing more.
                                          Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
                                          06-20-2025, 08:54 AM
                                        • ChristianBr01
                                          Dell 34 inch U3419W Monitor with thin stripes on partial screen
                                          by ChristianBr01
                                          I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
                                          This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
                                          This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
                                          Does someone have seen this before?...
                                          05-23-2025, 06:06 AM
