ASUS VH222H 21" : no power when LCD plugged
  • _max_
    • Dec 2012
    • 46
    • Italy
    Dear friends,
    my ASUS VH222H 21 inch monitor suddenly is no longer running, the power button does not have effect and the blu pwr led remains off.
    I completely disassembled the monitor to do a visual inspection.
    Unfortunately, even using a magnifying glass, I have not been able to identify any damaged capacitor, no component visibly burned or damaged runways.
    I did a test just by connecting the high voltage to the LCD panel, leaving disconnect the LVDS cable, and surprisingly the monitor turns on and the display lights up. Of course, no image appears.
    If I connect the LVDS cable, the monitor remains black and not even turn on.
    Monday morning I would like to take some high resolution photos of the main board and power board to post here, if I had missed some details you might definitely help me.
    In the meantime, I would argue with you experts on what could be the cause of such a failure.
    For example, since the display lights up, is it fair to exclude a priori a problem on the inverter / high voltage circuit?
    thanks
    max
  • selldoor
    Slow Learner
    • 7870
    Re: ASUS VH222H 21" : no power when LCD plugged
    max
    How did you apply the high voltage - what voltage? Was this from an external source.
    • _max_
      • Dec 2012
      • 46
      • Italy
      I just connected all the connectors for LCD lamps , mainboard, power board but leaving the LVDS cable unplugged.
      No external surces connected.
      • selldoor
        Slow Learner
        • 7870
        Ok Have you ohme tested the lvds cable for shorts. check for bent pins on connectors.
        Pictures on Monday might help - one of the tcon or panel board as well.
        • _max_
          • Dec 2012
          • 46
          • Italy
          Here there are my last pictures of the boards: Main Board and Power Board.
          It looks like there are no bad caps or other broken components.
          What is strange is that only when the LVDS cable is plugged, the monitor does not switch on.
          • _max_
            • Dec 2012
            • 46
            • Italy
            Here are a few pages with schematic diagrams of a similar power board
            @selldoor
            I really do not see how I can lead to short circuit in the LVDS cable or bent pins ... it is really crowded... How may have been broken by itself?
            It presented this defect suddenly and had never been opened before.
            • selldoor
              Slow Learner
              • 7870
              @selldoor
              Well that's ok then . You can apply that thinking to to the entire set and every component on it. If your not going to test the part that is causing the problem
              I will just move on to someone elses thread - bye.
              Perhaps someone else will suggest something that is easier for you test.
              • _max_
                • Dec 2012
                • 46
                • Italy
                Thank you selldoor, any suggestion is welcome!
                Only it is a bit difficult to find pins to check with the multimeter.
                • _max_
                  • Dec 2012
                  • 46
                  • Italy
                  No idea here?
                  I am stuck, I have not to much experience repairing display
                  • _max_
                    • Dec 2012
                    • 46
                    • Italy
                    I am stuck
                    • myth77
                      ASUS PG27U MONITOR
                      by myth77
                      First, i dont work on monitors only on laptops and that also for a hobby. So, i received this monitor in the title and it was completely dead, and power supply when used was going off to a power protection. I found that one of the voltage regulators for backlight GS9238 is dead, so i replaced it and monitor is working fine now. But...on the main motherboard first thing i tested was a main power rail and after power jack there is one mosfet Nikos PD537BA. The thing is when i tested all pins of that mosfet are shorted in between. Now when i plug the adapter the monitor just goes on. I dont think...
                      03-19-2024, 08:58 AM
                      ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                      This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                      09-07-2024, 02:50 AM
                      ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                      This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                      ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                      This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                      ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook Specification for Upgrade or Repair
                      This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                      09-07-2024, 01:30 AM
