Philips 170B LCD - OK for a few minutes then image starts going on and off
  • Agent24
    I see dead caps
    • Oct 2007
    • 5039
    • New Zealand
    Here's a real interesting one... a Philips 170B7CB/75 that I was told (hmm..) had fallen off a desk.
    It works OK from cold, but after a little while (1-2) minutes the screen goes blank, then a few seconds later, the image comes back. Then the image goes on and off at random intervals of a few seconds.
    PSU capacitors are Hermei and Elite, BUT they test perfectly fine for ESR\Capacitance out of circuit.
    Logic board capacitors are UCC KY which I did not test.
    Some detailed observations:
    1) The backlights shut off but this seems because the inverter gets a shutdown command from logic board (backlight enable signal goes from 3v to 0v)
    2) The power LED sometimes stays on, sometimes goes off.
    3) Sometimes when the backlights come back on, the image is gone and it displays a white screen instead.
    4) After some time it seems the CPU gets confused. Buttons lock themselves, OSD changes location, image settings become corrupted. A reset (in the OSD menu) fixes this.
    5) Powering one of the CCFLs from a separate inverter, it can be seen that during the backlight off time, the image disappears too, and the LCD panel switches sometimes between full black and seemingly totally powered off.
    I thought one of the logic board regulators could be failing. But I can monitor the voltage on both (3.3v and 1.8v) regulators and they both stay stable as a rock the whole time. (4th meter showing 1.8v rail not in photos)
    What I did notice is that while the screen is blank, the 5v rail dips slightly from 4.99v to 4.73v. The 12v rail which is about 12.3v during operation, rises to 14.2v during the fault condition.
    (In soft-off mode the voltages are about halfway between those, 4.89v and 13.2v)
    Anyone heard of anythng like this before? It's very strange.
    -David VanHorn
  • Agent24
    I see dead caps
    • Oct 2007
    • 5039
    • New Zealand
    Re: Philips 170B LCD - OK for a few minutes then image starts going on and off
    Just thought of something else to try.
    Disconnected the LVDS connector from the panel and got (as expected) a white screen. This also starts flickering on and off after a short time. So I guess that rules out the panel and T-CON as being faulty, at least.
    -David VanHorn
    • Agent24
      I see dead caps
      • Oct 2007
      • 5039
      • New Zealand
      It's not the audio amplifier, or the button board either. Same problem with those disconnected as well.
      Service manual mentions checking the MCU crystal for a no image problem, and I figure if it had taken a tumble the crystal might have ended up cracked or such, so I had a look at that but the waveform stays unchanged throughout the fault so it doesn't seem to be an issue.
      I'm thinking it's something heat related since from cold it works for longer before going insane. Maybe time to get some freezer spray...
      Since I'm down to PSU or Logic board definitely, I will probably try an external PSU+inverter and see if that makes any difference. That should narrow it down to which board is bad.
      Also I notice the logic board and schematic have an RS232 and a SPI 'Debug' connector (unpopulated). Might see if anything interesting comes out of either of those.
      -David VanHorn
      • selldoor
        Slow Learner
        • 7870
        Good pictures of front and backs of the boards may help??
        I have had similar problems with different monitors one was fixed by replacing the BIG cap
        so perhaps you could monitor that.
        Another was on one with a separate inverter board- I had "repaired " it some months earlier
        replacing the two caps - worked fine for a quick test so put it aside. My son borrowed it and a few days later came back with "it keeps switching off and on"- sure enough it did.
        Went right through the power supply testing and ended up one of my solder joints on one of the inverter caps was crapping out pulling the whole thing down.
        So I would try reflowing all the inverter section.
        Also as it has been dropped I would reflow the BIG transformer as its weight and the momentum could have cracked the solder?
        • Agent24
          I see dead caps
          • Oct 2007
          • 5039
          • New Zealand
          I already checked the primary filter capacitor, ESR and capacitance was OK too.
          Solder joints on the SMPS transformer look good.
          I found that when unplugging the VGA signal cable to force the monitor to momentarily power off the panel\lights, the PSU voltages changed in the same way as during the fault. I think it's probably the load changing (panel and lights going off) that causes the voltages to change, not the other way around. Which makes me suspect the logic board.
          Anyway, I'm currently running the power supply by itself with some test lamps for fun. I doubt this will prove much though.
          -David VanHorn
          • Agent24
            I see dead caps
            • Oct 2007
            • 5039
            • New Zealand
            Well, the PSU seemed fine running by itself with test lamps (as I expected, though no load on 5v rail, so not conclusive) so then I tried running the monitor from the 12v and 5v rails of an ATX PSU, and a backlight from my external inverter.
            I still got the problem with that set up, so I think I can say for sure it's the logic board at fault here.
            Also I managed to make it go crazy faster by putting my desk lamp over the board and heating it up, so I really do think it's a heat issue too.
            If I can pinpoint the part.. it should be fixable. But not if it's the MCU. Even though I could get one, it's too expensive for such an old monitor and I don't have the firmware image anyway. But for anyone who wants the Novatek Easywriter ISP programming software, it's here. Good luck with figuring out the ISP board wiring!
            -David VanHorn
            • selldoor
              Slow Learner
              • 7870
              Do you mean unplug the vga signal cable that comes from the PC? I didnt think that would cause the lights to go out? How about trying a different vga cable. Could it be anything to do with the 5v pin on the vga (pin9)
              • Agent24
                I see dead caps
                • Oct 2007
                • 5039
                • New Zealand
                Most monitors turn the backlights and panel off temporarily when the video cable is plugged in or unplugged, before turning them back on to display the image or the "No signal" message.
                I did this just to see if the 5v rail voltage drop was being caused by the PSU itself or the panel switching off. At first I thought the voltage was dropping and causing a system reset, but I think it's just how the PSU responds to the drop in current draw.
                A different cable and another computer were one of the first things I tried. No difference.
                I don't think Pin 9 would be related. As far as I know, that just powers the EDID EEPROM so the computer can read the monitor information, even when it's switched off.
                -David VanHorn
                • selldoor
                  Slow Learner
                  • 7870
                  Guess I have never noticed though I usually have the monitor off when plugging in/out
                  Thought you would have tried another cable and yes I thought the 5v was only for the edid and only on some monitors but think I did see somewhere where the
                  5v was somehow causing a problem , but just clutching at straws
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5039
                    • New Zealand
                    I'm sure now the MCU is bad.
                    Alternate heating with a small hot air nozzle and cooling of the IC makes the symptoms appear and disappear.
                    Since I have no firmware to load into a new chip, it looks like I lost the fight this time.
                    But I did come up with a clever idea - instead of freezer spray, I had the idea of putting a chunk of ice from the freezer in a zip-loc bag and using that instead. Works great, for large parts like a 128-Pin QFP...
                    Not very accurate for anything else though.
                    -David VanHorn
                    • malekservis
                      Philips 58PUS8536/12 Backlight ok, no image
                      by malekservis
                      the TV turns on fine, seems to be working, but shows no image outside of a thick white vertical line as it turns on that also disappears almost instantly, and then it's just backlight. I've tried unplugging either side, but still can't get an image. I suspect it's a panel issue, but thought i'd ask some smarter people to confirm. I haven't found any weird readings, but then again i'm just randomly poking around with a multimeter.
                      Any information would be appreciated....
                      08-07-2024, 07:48 AM
                      HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                      This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                      09-12-2024, 02:20 PM
                    • Kartowl
                      philips 47pfl6158k/12 image faded away, sound still coming from TV
                      by Kartowl
                      Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                      04-23-2024, 12:57 AM
                    • Jaime Morillo
                      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                      by Jaime Morillo
                      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                      The TV was stuck on the logo and I couldn't access the update menu.
                      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                      The image result was good, but the image is inverted.
                      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                      08-18-2025, 11:38 AM
                    • Raulnn
                      Tv Philips 55PUS6031 no image, backlight ok
                      by Raulnn
                      good night! I have this TV, with quite poor build quality. It has a tcon integrated into the panel, a single flex from the tcon to the panel, and the 2 panel controller boards joined by glued flexes. There is no way to separate them.
                      The symptom is that the image is not visible, but the backlight works. How to know if the problem is in the main or in the tcon-panel? I can't override zones.
                      05-14-2024, 02:11 PM
