Dell Ultrasharp 2408wfp Shadows
  • hgg
    • Oct 2014
    • 24
    • Greece
    Hi to all,
    My name is George, and I am a new member to the forum.
    I have the Dell 2408wfp LCD monitor many years now and it has developed a
    strange problem. Its more than a year and it has not gotten any worse.
    Some dark shadows have appeared on the right side of the panel.
    When you press on the LCD screen at the location of the shadows,
    they do not change. The problem is more visible at low brightness
    levels 20% (which I work most of the time) and less pronounced at
    higher levels like 60% There is no similar pattern at the background
    picture I am using. I have used the LCD conditioning function from the
    menu, but it does not make any difference.
    Please have a look at the image below :
    I would like to hear your opinion on what could be the most likely cause
    of the problem and if it is reversible. Any help is appreciated.
    Thank you!
    George.
  • Agent24
    I see dead caps
    • Oct 2007
    • 4953
    • New Zealand
    Re: Dell Ultrasharp 2408wfp Shadows
    You can get dark patches on LCDs if they have had physical damage.
    Did the dark patch appear gradually or all at once?
    If it's not the LCD itself, there maybe something inside the panel assembly, behind the LCD glass.
    At a guess, it could be carbon residue from a failing\arcing CCFL lead. But that should cause inverter shutdown...
    Can you post a more close-up image of the area? Preferably a macro shot as close as you can get, maybe taken from an angle rather than perpendicular to the screen.
    -David VanHorn
    • hgg
      • Oct 2014
      • 24
      • Greece
      The dark patches appeared gradually in a period of a month or so.
      This is the closest I can get:
      It looks like its something immediately below the lcd screen but not
      anything like a carbon residue.
      George.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4953
        • New Zealand
        Mould? Did it ever get damp\wet?
        -David VanHorn
        • hgg
          • Oct 2014
          • 24
          • Greece
          Its not mould.
          Today I got my heat gun and heated the affected area at 100 degrees C
          and after a while the shadows disappeared! Half an hour later they were back
          again exactly as before...
          It looks like there is a sort of permanent damage inside the LCD layering.
          • HAHOMETP
            • Nov 2012
            • 155
            I suspect moisture is trapped between the backlight diffuser sheets. Those sheets look like mica, are polarised and stacked in a cross-hatch pattern. I'd take this whole sandwich apart on a large clean table and look before chalking off the LCD. Be sure to note the sequence and the orientation of those sheets as you peel them off. They will need to come back in exactly the same order and orientation.
            I have the same problem, albeit far less pronounced, in my larger Dell 3007wfp but don't have the time to address it at the moment.
            • hgg
              • Oct 2014
              • 24
              • Greece
              Risky business... but when I find the time I will try it.
              It looks like that the wfp series develops the same problem after prolonged use.
              Thanks.
              • HAHOMETP
                • Nov 2012
                • 155
                My problem is entirely man made. I took the backlight diffuser sandwich apart for cleaning with alcohol but put it back together too hastily w/o waiting for the alcohol to dry completely between the layers. Need to revisit it one day.
                • hgg
                  • Oct 2014
                  • 24
                  • Greece
                  I see. I thought that is appeared by itself.
                  There are other owners though that have similar problems with the 2408wfp.
                  Did you clean them with ordinary rubbing alcohol?
                  • HAHOMETP
                    • Nov 2012
                    • 155
                    Yes, it was regular rubbing alcohol. I wish I had some Methanol at that time. It leaves no residue but is very toxic and as such is not sold freely in the US.
                    Washing those large diffuser sheets is challenging because they have miniscule ribs running diagonally that like to trap moisture. They resemble Fresnel lenses only the grooves are not circular but straight.
                    • hgg
                      • Oct 2014
                      • 24
                      • Greece
                      Thanks! I might try it.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4953
                        • New Zealand
                        Could indicate a manufacturing problem. Or that the design is susceptible to this problem.
                        -David VanHorn
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                        • F R 2568
                          Dell Latitude 5420 does not start (no post) need help to find the reason why
                          by F R 2568
                          Hello all,
                          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                          If the laptop is only connected to the AC adapter (battery removed):
                          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                          The power/battery...
                          01-08-2025, 05:45 AM
                        • diamon
                          Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                          by diamon
                          I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                          Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                          Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                          Pictures of these boards:
                          Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                          Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                          Dell...
                          02-28-2024, 12:51 PM
                        • master3112
                          by master3112
                          07-29-2025, 01:55 PM
                        • OntarioTL
                          Dell 5410 greyed out BT
                          by OntarioTL
                          Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
                          If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
                          Dell Lattitude 5410
                          Service Tag...
                          07-25-2025, 01:28 PM
