Samsung S24B300 Garbled Screen
  • leggot
    • Oct 2014
    • 50
    I have a Samsung S24B300 that has an issue in which the screen is garbled when first turned on. After times varying from 5-20 seconds the screen resolves itself, but has red snow when displaying black.
    The main circuit board is labeled sa350 and is the version with VGA and HDMI connectors, however I believe that the issue is within the tcon board. Anytime the screen is garbled, there is a high pitched noise coming from a cluster of components but when the issue resolves itself, the noise disappears.
    I tested the powersupply, it is rated for 14v and it varies from 15 - 14v depending on the board and it also has a center pain making it non standard.
    I believe the noise is coming from a capacitor that is going bad, I tested all the resistance for the capacitors in the region and the one with the lowest C18 1.06 ohms.
    My theories are bad/cracked solder, broken or intermittent capacitors or that the power supply is not supplying enough wattage. Please let me know what you think.
    Tcon board:
    Tcon part numbers (I couldnt find any diagrams online):
    Here is an image of the garbled screen:
    And the service manual: http://www.go-gddq.com/upload/2011-1...2610175323.pdf
  • leggot
    • Oct 2014
    • 50
    Re: Samsung S24B300 Garbled Screen
    As an addition, I also ensured that the panel has the latest firmware update from samsung.
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
    • Chrissygizmo
      samsung galaxy ao2s very temperamental after screen replaced
      by Chrissygizmo
      Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
      Ive eventually managed to get it on and working but it's very temperamental...
      The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
      05-26-2024, 12:05 AM
    • JunkmanJimbo
      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
      by JunkmanJimbo
      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
      No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
      Please help. Thanks in advance!
      08-12-2025, 11:45 AM
    • Kiberge
      Samsung LH82QENELGC/EN Help needed - Static line on screen
      by Kiberge
      HI guys!
      I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
      I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
      the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
      This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
      04-22-2024, 11:28 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
