need help Board start only when its hot ??
  • Richi_el
    • Nov 2013
    • 95
    • Koln
    Hi @ all
    i have machine and some problems with it...
    the board is from a machine and has a typical problem..
    sometimes it starts and sometimes not..
    allways when i heat the the board with a heater gun it starts.
    ive tried many things ... but i didnt find out whats the reason..
    Pic 1 is the whole board in top view
    Pic 2 is the whole board groung view
    Pic 3 is the a part of board (power supply 13V + 2x 5V)
    mostly i heat this part of board an it works
    Pic 4 is the same part of board in bigger view
    pic 5 is the ground view of this part of board in bigger view
    so maybe someone has some informations for me please because iam also a newbie in this and dont know all parts..
    can someone find any thermic elements on this board ?
    is the lc244a on pic 5 maybee a reason ???
    please help
  • Richi_el
    • Nov 2013
    • 95
    • Koln
    Re: need help Board start only when its hot ??
    TOp view
    • Richi_el
      • Nov 2013
      • 95
      • Koln
      Ground view
      • Richi_el
        • Nov 2013
        • 95
        • Koln
        PIC 3 Power supply
        • Richi_el
          • Nov 2013
          • 95
          • Koln
          Pic 4 Bigger view
          • Richi_el
            • Nov 2013
            • 95
            • Koln
            pic 5 bottom side
            • kasfamily
              • Aug 2014
              • 765
              • Russia
              1- pic3 U101 badly soldered. 2-Should be localized using a thin nozzle for heat gun
              • Richi_el
                • Nov 2013
                • 95
                • Koln
                Edit :
                Mosfet u101 is reworked now---> same problem...
                But
                Today ive desolderd bga in pic 1 and the board start aswell without any heating process.
                It seems that the problem is by bga ..its a via but wich one ?
                Is someone able to tell me the correct type of it ??
                I cant find this bga on google or somewhere else....
                I works in combination with the bga on pic 2 via cx700 ....
                • Richi_el
                  • Nov 2013
                  • 95
                  • Koln
                  I have to cancel my last post , also the same problem without bga ....
                  It seem to be a thermal problem...
                  This i bga wich ive disolderd
                  • dragos2009
                    • Mar 2013
                    • 110
                    • Romania
                    that is a via c7-m processor 1ghz/400mhz fsb http://www.cpu-world.com/CPUs/C7-M/V...obileBGA).html
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • Rezendes
                      Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                      by Rezendes
                      Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                      I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                      The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                      05-10-2024, 02:18 PM
                    • Garret Matt.
                      DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
                      by Garret Matt.
                      I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
                      Thank you in advance for any assistance you can render.
                      Inductor In question. Buzzes like...
                      06-20-2025, 01:21 PM
