Asus VW221 (model VW221d)
    Hi guys
    So I have this Asus VW221. Its problem is, the backlight's not working at all. No seconds to black. It's all black right away. There's a picture on the screen, all OK as it should be, just no backlight.
    I opened it up, and there are no bulged caps, visually, nothing out of the ordinary. Little did I find about this screen and this problem, but some are talking about trafo(s).
    Here are the photos, and I hope someone will be able to help
    Re: Asus VW221 (model VW221d)
    Check the SMD fuses (F801, F902) by the connector CN902. If F801 is blown, then you may have bad Q802, Q803.
      they're up and running
        How? Details?
          I meant fuses, sorry. They are not blown
            Check to see if the 12-14VDC is present at the fuses F801 and F902.
              16.13 V on both fuses
                And one correction. Picture appears for about half a second. I was mistaken at first
                  Can you provide the P/N as printed on the two inverter transformers so we can look up the pinout to check the HV winding resistance? Also get te P/N of the two SMD MOSFET so we can verify if they are OK or not.
                  You can have lamps problem also.
                    Here's trafos.
                    Now, if I'm not mistaken, I see four mosfets here. One on the top side, a three on the bottom side. Which ones are you interested in?
                      There are only two power SMD MOSFET: Q802, Q803. They are Dual-MOSFET (two MOSFETs in one package).
                        Dammit, now it's so obvious. Well, excuse my ignorance.
                        "NIKOS P5506HVG" both of them
                          You can try taking a resistance measurement across the secondary of each inverter transformer. I believe they are pins 8 and 9 stamped on the bottom of the board.
                          You can check each of the P5506 mosfets for shorts. Each P5506 contains two mosfets. With your meter set to resistance check the combination for each P5506:
                          G1-->S1
                          G1-->D1
                          S1-->D1
                          G2-->S2
                          G2-->D2
                          S2-->D2
                            With my multimeter (Mastech MS8200G) set to 2k the inverter transformer readings are:
                            T802 - .813
                            T801 - .838
                            As for the mosfet readings, my multimeter is set to continuity test, or 2 ohms. That is the only setting that gives any reading.
                            Mosfet Q802:
                            Red probe on S1 Black on G1 - 1.305
                            Black on S1 Red on G1 - .664
                            Black on G1 Red on D1 - 1.879 after some time. Looks like mosfet is charging up.
                            Black on D1 Red on G1 - .961 (meter beeps for continuity for a second and then stops and gives measurement. edit: beep happens only the first time. every other measurement gives no continuity)
                            Black on S1 Red on D1 - Meter beeps for continuity for a brief moment and then it goest to infinite resistance
                            Black on D1 Red on S1 - Meter beeps for continuity for about a second and then measures .315
                            Red probe on S2 Black on G2 - 1.305
                            Black on S2 Red on G2 - .663
                            Black on G2 Red on D2 - 1.885 after some time. Looks like mosfet is charging up.
                            Black on D2 Red on G2 - .959 (meter beeps for continuity for a second and then stops and gives measurement. edit: beep happens only the first time. every other measurement gives no continuity)
                            Black on S2 Red on D2 - Meter beeps for continuity (only the first time) for a brief moment and then it goest to infinite resistance
                            Black on D2 Red on S2 - Meter beeps for continuity (only the first time) for about a second and then measures .314
                              Mosfet Q803:
                              Red probe on S1 Black on G1 - 1.303
                              Black on S1 Red on G1 - .663
                              Black on G1 Red on D1 - 1.880 after some time. Looks like mosfet is charging up.
                              Black on D1 Red on G1 - .958 (meter beeps for continuity for a second and then stops and gives measurement. edit: beep happens only the first time. every other measurement gives no continuity)
                              Black on D1 Red on S1 - Meter beeps for continuity for about a second and then measures .313
                              Red probe on S2 Black on G2 - 1.303
                              Black on S2 Red on G2 - .662
                              Black on D2 Red on G2 - meter beeps for continuity and then shows infinite resistance
                              Black on D2 Red on S2 - Meter beeps for continuity (only the first time) for about a second and then measures .313
                                I believe the continuity setting on your meter is the same as the diode check setting and what you're reading is voltage and not resistance. From what you said, you tried measuring resistance on all resistance settings and saw nothing? The meter does read zero ohms when you touch the pos and neg probes together, correct? Is it's battery good?
                                  Battery is new.
                                  Yes, resistance is zero on all other settings
                                    I don't think I've ever heard of all 4 mosfets on Q802 and Q803 shorted out, but if you're reading zero ohms for each measurement, then they'll need to be replaced.
                                      well whadiya know. I replaced the battery and the results were the same.
                                      So i got another multimeter (another mastech) and the results are now different
                                      multimeter's set to 2k.
                                      q802
                                      G1-->S1 - 1.609
                                      G1-->D1 - 1.094
                                      S1-->D1 - 0.267
                                      G2-->S2 - 1.612
                                      G2-->D2 - 1.093
                                      S2-->D2 - 0.267
                                      q803
                                      G1-->S1 - 1.609
                                      G1-->D1 - 1.093
                                      S1-->D1 - 0.267
                                      G2-->S2 - 1.612
                                      G2-->D2 - 1.093
                                      S2-->D2 - 0.267
                                        Check T801 and T802 again. If those readings are consistent I would check the CCFL bulbs using budm's method in post #2.
