Envision EN7100si Flashes on and off [FIXED]
  • spetragl
    • Aug 2014
    I have an Envision EN7100si that flashed on and off, but thanks to the advice on this forum, it was fixed.
    The monitor first started acting up a while back and the initial advice was to turn down the brightness. Well that worked for a few months, but the flashing started getting worse. Eventually one night it failed and would not stay on.
    Searching through this forum (and others) I sought instructions on how to open it. Most of the people simply say to just remove 4 screws at the corners, then use a blunt object to run around the edges and separate the front from the back.
    Unfortunately one important instruction was missing.
    After much prying and pulling, I found that on the back on the stand pivot were 2 black "U" shaped covers. Once I pulled these off I found 8 screws holding the stand to the monitor. Removing these screws, then running a blunt object around the frame, the back finally came off.
    Now following everyone's advice I located 2 buldging caps in the power supply. So I went to my friendly Radio Shack (I know bad move) and purchased 2 new caps. I soldered in #1 and tried the monitor, it still flashed. So I replaced #2 and tried it again; now NOTHING.
    OK, I said don't panic; it had to be the last cap that made it worse.
    Going back to the forum I read good things about Digikey.
    So I ordered my 62 cent capacitor + $3 shipping.
    When it arrived I carefully removed the last cap and soldered in the good one.
    I powered the monitor up and to my surprise it came on and stayed on, even at full brightness!
    So to all of the Techs out there, thanks for all of the help!!!
    - Steve
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • odie34
    Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
    by odie34
    I am a hobbyist (not a professional) so please be gentle...
    I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
    I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
    02-18-2024, 09:11 AM
  • howardc64
    Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
    by howardc64
    TV was fixed just after removing Samsung's rear snap cover.
    This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
    Maybe PSU->backlight connector didn't have a good contact?...
    07-23-2025, 12:34 AM
  • cajoeg
    Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
    by cajoeg
    Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
    The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
    02-10-2025, 04:01 PM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
