Samsung Monitor S19F350 19
  • bennn
    • Mar 2023
    • 15
    Which resistor?
    Hello, the one I circled in red.
    I think it somehow interacts with the MOP transistor. It is signed as r921. Considering that the backlight does not light up 100%, most likely it is.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5095
      • New Zealand
      I think you forgot to upload the picture. We can't see anything with a circled resistor on it here...
      -David VanHorn
      • CapLeaker
        Leaking Member
        • 8352
        It is there. Right underneath the mosfet. Between the cap and the inductor.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5095
          • New Zealand
          Are you talking about the current sense resistor under the circled mosfet, about a dozen posts ago? Makes sense that would fail if the mosfet went bad, yeah. Could also have damaged the CS input on the IC...
          -David VanHorn
          • CapLeaker
            Leaking Member
            • 8352
            The mosfet didn’t fail neither that resistor. He just resoldered that resistor.
              09-07-2024, 05:50 AM
              by momaka
              03-15-2023, 10:17 PM
            • keepread
              Dell monitor PSU vs Dell laptop PSU
              by keepread
              Hi there!
              Someone gave me their old monitor, it's Dell S2715ht.
              The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
              Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
              10-30-2025, 04:45 PM
              09-06-2024, 11:40 PM
